T56 Impala
So I have a few old wheels here. Both are beyond repair. One BMW Style 32 and one Audi style???. I'd like to mount them to the wall to hang an air hose on or maybe a garden hose. How would you suggest mounting them?
GRK Lag Bolt if you can get to a stud with two of the bolt holes. If not, Mount wheel to a 2x that is long enough to reach 2 studs.
That is sick. What does that wheel fit? I have some 17" OZ wheels off a Viper and the rears are at least 12" wide. They are Magnesium.Here is what I did with some square tubing, threaded rod, a long nut and a hockey puck.
Thank you. It’s a rear wheel off of Vettel’s Red Bull F1 car. Crazy light at about 14” diameter and width.That is sick. What does that wheel fit? I have some 17" OZ wheels off a Viper and the rears are at least 12" wide. They are Magnesium.
Sent from my VS987 using Tapatalk
X2. Easy and done. This is how I mounted mine...I drilled a hole in the lip where the bead seals. One on the top and one on the bottom and used two deck screws to mount it to a wall stud. It was a 1952 chevy steel wheel and I put the center cap on it.
Sent from my SM-A102U using Tapatalk
