Shiftless, If you’d like to trade one of those,or its cash equivalent, for this let me know. But I do see your point.
They could be drilled but they’re done well. I could be wrong, but I don’t believe mine has removable jaw faces either.
Your 614 is a factory stationary base model, hence the "beard." Their later model vises, including Starrett ( parent company ) used the same cast for both stationary and swivel base models, so they employed a smooth bottom base. They had 3 bolt down points in the stationary configuration. One or both of the side holes were used for the swivel locks in swivel configuration. You'll notice the third hole in the rear remains, even though it serves no purpose in the swivel configuration on the later models.A friend gave me this Athol 614, It was his Grandfathers. it's in pretty nice shape under the paint, smooth jaws like my 614-1/2 user but it has the registration "lump" on the front of the base unlike my user.
I would like to see some Athol paperwork showing the option of a smooth base and smooth jaws. At first I thought Lockheed had milled off the "lump" themselves on my 614-1/2, but I've seen at least a half dozen Athols now with a flat bAse that I know it is factory.
floyd612...I don't think that the holes were original. I found about -5- catalog scans, none of which had the holes in the illustrations. The pin removed would allow for the back jaw to swivel for odd shaped items. The catalog scan below is from 1876.
I like the vise outside on the concrete pedestal. Kinda gives a feeling of an outdoor museum.
I need an offset jaw vice to hold motorcycle fork tubes while servicing them. Anyone in SoCal have an extra they'd be willing to trade for a Wilton 400S?
davethorik- I've seen that ugly orange vise on CL for a while too. Wow, what an interesting quick-acting setup. Good job chasing after it. Makes me think I need to pursue some more of those oddballs.
Unscrew the slide and pull it out.
The date will be on the key stock.
Got an odd duck today. It's been languishing on Craigslist for a few months, one small crappy pic. I dismissed it at first, thinking frankenvise. Until I stumbled across a Google books of an old industrial supply type place, listing this Massey Vise Co. Riley patent "Lightning Grip" quick set vise.
https://patents.google.com/patent/US227582A/en
I also found this ad from 1896, and it looks like they could be had as fixed base or thru-bench swivel base. These appear to be swivel base. If so, that would make my 3.5" a #11.
The vise weighs in at 43 lbs and opens 4". Attached is a pic of the cam on the end of the spindle that actuates the smaller rack, pushing it up into the large rack in the top half of the vise body to tighten. It only takes 1/4 turn of the heavy cast iron handle to accomplish this. As a side note, this looks like the same handle found on Massey's quick release woodworking vise.
For the bad, the wing nut has both ends snapped off, but it's there. I'm not sure if the swivel base is original, but it's been with the vise long enough to get the same crappy orange paint. I don't know about the stud, guessing stack-o-washers isn't original
There is also a chip under the dynamic jaw pad. For some reason the two halves of the body are bolted together backwards.
I've never seen one before. I think it's pretty cool. Looks like Massey was around 1890s-1920s. I'm just assuming here, the vise has no markings I can see yet. Maybe Fierljeppen knows more.
What can you learned viceologists tell me about this
It works perfectly, but I do plan to refinish it soon.
Any pro-tips on the best way to clean the slide, or a source for paint?
Reverse - that 46 cleaned up great! How bad are the cracks in the base? Also, did you bake on the BLO? Nice work.
Dave - that is an odd duck, but very very cool. Nice pick up!
R.P.:
That BLO finish looks great!
Do you have a separate dedicated gas grill for baking BLO parts or can you use the same one for grilling steaks and vises?
Get:
I agree with your tips about paint colors and for using scotch brite for polishing. I also use those 3 inch diameter scotch brite drill mounted flap wheels.
Thanks
I was concerned that some lingering BLO smell would affect the taste of food later cooked on the same grill. Maybe grilling the vise parts with the lid open would be less risky re: lingering BLO odor.
