Angle grinder - wow
ourkid2000
Nova Scotia
So I'm just getting started using my new angle grinder. I've never used em until I bought one a few days ago.
Anyways, these things are quite dangerous! Using it I can see how you could easily get bitten bad by it. The other nasty thing about mine is that when you push the switch forward, it clicks in and it won't stop until you click the switch back, no dead man switch. If the thing got loose it would just keep running around doing untold destruction until it either sliced its own power cord or got jammed on something.
I have to admit, I was quite scared of it.......I was extremely cautious using it but it still seems like an accident waiting to happen.
sammerdog
West Michigan
You're being smart to respect your grinder.
Wear eye protection! Better yet, eye protection AND a face shield. Sparks will fly.
Grip the thing firmly, like you mean business and never never never run the wheel in a position where you'd get hit if the disc comes apart.
But dangnabitall - once you use one for slicing metal conduit, etc - you'll wonder why you didn't buy one sooner.
Shadowdog500
Down the shore
I also think it is good that you respect your new tool.
We had a pretty good thread on angle grinder safety about a month ago. The main points were to keep the shield on, wear a face shield, and never put your face/body in the plane of rotation incase the wheel blows apart.
Chris
nolatoolguy
Louisiana
Yes, angle grindrrs can be very dangerous. Anything can be dangerous even paperclips. Powertools expecially require catuion. Its common for grinders to have a lock on lock off type switch. Be carefull and the number one thing i can stress is that wait till the disc stops spinning to set it down and always set it down with the blade facing up and motor on its back
superautobacs
Vancouver, BC
I might add:
Wear some heavy, leather gloves, too.
Depending on what you're grinding, be aware of what you might be inhaling.
I never set the grinder down until it's stopped spinning--other than that, is there a reason behind this?
rodm1
I like to use a old welding hood with a clear glass lens sandwiched with two plastic lenses. I used to hat grinding because of the abrasive and grinding dust hitting you in your face still do but this makes it lots better.
iamhomeless
Indy
Respect the tool, but don't be afraid of it. It is an inanimate object that requires your manipulation for it to function. Grip it and take control. Confidence is required so that you can be sure of your actions and how the tool and material to be cut will react. If you are scared of the grinder you will cut something that you do not want cut.
And use your ppe, I have a set of safety glasses that have steel embedded in the lenses from grinding. Eye pro and gloves are the minimum, a shield an ear plugs are better.
MikeinLA
I need to buy an angle grinder to cut a stainless steel sink out of a boat (there's no other way to get it out). Thanks for the tips.
Mike
chevyboy91188
Tampa, Fl
wire wheels on angle grinders are a no no I have two nice scars where it caught an edge on my frame and spun out of my hands. brushed away a nice piece of flesh both times first time was the back of my hand so I started wearing gloves, second time was my forearm so now I wear a damn full body suit practically lol
brokenknee
Northern, MN
Yep, you can still see a scar on my left hand, from what was then a new angle grinder twenty five years ago. :( I got careless setting it down when I was done with it.)
caper
cape breton
You think that's dangerous you should try a real one with a 7 or 9" disc.Use one of those suckers for awhile and you really get a good upper body workout.
rsanter
visalia ca
the danger of a mini grinder is proportional to the operators carelessness, ignorance or stupidity
and I do not like the type with the locking switch, I prefer the paddle type that you have to hold
whatever you do, do not hold something in one hand and grind, sand, or wire wheel with the other
a friend learned that the hard way
bob
Pathfinder
Newbury, MA
I use the chain saw tooth cutter on mine for fitting log joints. Absolutely the best tool for the job. Imagine my surprise when I plugged in my grinder one day and the thing went skating across my deck on the chain saw blade until it unplugged itself. You guessed it. A Harbor Freight grinder with a switch that failed in the on position. That was a close one.
John Minton
O
ourkid2000
Nova Scotia
I can't even imagine. Even my little one feels like it has got some serious torque from that spinning disc.
cdent
Be careful of the sparks, they can start a fire very easily. I'd wear dust, eye and hearing protection and stay out of the line of fire like others have mentioned.
nolatoolguy
Louisiana
I might add:
Imigane a switch on switch off swith your grinder is unplugged you go to plug it in you forgot you had it in on position all the sudden it starts spinning by time you unplug it its already started a little
does it make sense not sure i explaned it clearly
1320stang
Edmond, OK
Yeah, a lot of guys don't like the paddle switches, but I prefer them. I need to get a new switch for my old paddle Dewalt, my new Dewalt has the on/off that I don't care as much for. Plus the old one had the rubber pad for sanding disks, the new one I had to buy a Norton back and modify it to work.
nate379
Palmer, AK
What's the story with that? I do what your described all the time!
bob
Been using grinders for about 15 years and no injuries. I don't run guards on them either, get in the way too much.
rsanter
visalia ca
a friend was over doing some work in my garage
he was using a knotted wire wheel to clean up a bracket for me to weld
holding the bracket with one hand and the grinder with the other.
the wheel grabbed and jumped causing it to 'wheel' up his arm.
he was left with a nice stripe of 'road rash' across his hand and up his arm.
the wheel was full of grease, dirt, and rust so the wound was nice and dirty and the painfull to clean up
I never run a guard, but being carefull I have naver had more than the minor instance
bob
jeepnut24
Morrison CO
Yeah, my wire brush incident hit the end of my glove and the start of my shirt. Tore the shirt out and I have a nice scar as a result. Now its a heavier shirt when I run a wire brush.
e-tek
Saskatoon, SK
I might add:
That's the thing about this site. Lots of guys with REAL experience - I can tell because these are all things that WILL happend with your angle grinder!!!
I ALWAYS use a FULL face mask (after discs have come apart!), Welding gloves (after several deep cuts and harsh scrapes!) and - I make sure to GRIP IT TIGHT! If the thing catches an edge, you're either gripping it tight enough to overcome it's torque - or loosing your left nut - followed by the right!!!!:lol_hitti
I don't run a guard or 2nd handle either. It's ALL or NUTHIN!
speed bump
Butte Montana
Mike
Have fun with that, chances are darn good that all you'll do it piss your self off and ruin the stainless. Stainless is a job where a plasma cutter is the best thing to have
I've always had good luck with wire wheels, only thing I have had a problem with is a cutting wheel that got broke but I use a guard so it was a pretty boring experience.
quneur
bob
Why not use a bench grinder for that one?
rhastings80
I recently put in a new toilet in my Mom's house. The bolts that came out of the floor where too long once I had the toilet in place for the decorative caps. There wasn't much room between the wall and the toilet and I was trying to use a hack saw to cut the bolts and it was taking forever. I decided to use my small angler grinder which did work. However I guess I wasn't really thinking and all of those sparks and flying metal took off a good amount of the porcelain finish near the bottom of the toilet. Luckily you can't really see it on the toilet unless you get down on the ground. Just saying unless you are gutting your boat all of that flying **** will make a mess and damage other stuff in your boat.
Mike
Stick Figure
Omaha, Ne
i have a couple of scars from angle grinders. I now use a Makita with the paddle switch to make sure it shuts off if it rips out of your hands. The other advice is DO NOT use cheap cut off wheels in it. I don't care if you bought the tool at Harbor Freight or found an even cheaper one, do not go back for cut offs, wire wheels etc. I can say i would have a few less scars had i never tried to be cheap w/ cut off wheels.
FlameOut
Pittsburgh, Pennsylvania
Also be sure to protect any glass, or anything else that may get damaged from the sparks. You don't want to find out the hard way that you may need to replace a 40 year old piece of glass on your car, or whatever.
