I know that you have said that you want to go with propane, however, have you considered diesel? Fuel is easily stored, readily available, and a diesel generator is extremely efficient. I run mine on home heating oil. I installed an ASCO automatic transfer switch. Since we have frequent short outages, I have installed a switch between the automatic switch and the generator switch that I can turn off in the home, so the generator will not come on for short periods. If we were out for 8 or 12 hours, and the power failed, the generator will not come one, until we come home and flip the switch. If we are going to be gone for a longer time, we can either have a neighbor come over and turn on the generator by flipping the switch, or flip it before we leave. Something like this will save you a lot of fuel and can easily be installed on most units, regardless of the fuel type.
Before we got the generator, we would have 7 - 10 day power outages. After installing the generator, the longest one that we have had is about 12 hours. Seems that once you buy the generator, you won't need it, but it gives you peace of mind knowing that you have it.
