Hello all,
I wanted to thank you all in advance for any responses I will receive. This is a heating question for my shop and home.
My situation is that I have a forced air electric heated home and electric space heaters in my shop. My house has two electric furnaces heating about 3,300 sqft. We have a wood fireplace that supplements the heating in the winter time but its really not the best way to try and heat that much space. Due to the fact that our electric bill in the winter is pushing 650 bucks a month even with burning wood in our fireplace we are looking at different more cost effective options. The heaters in the shop are only used maybe once a week for a couple hours so the cost there is low.
We have considered adding another indoor fireplace or wood burner, or a wood add on furnace. Gas was considered as well but we are looking to be as economical as possible. We would like to stick to wood as I have a lifetime supply of firewood available, we like the heat firewood brings, and I enjoy cutting and splitting it. We are however tired of the mess that comes with bringing the wood in the house and with the placement of the electric furnaces (in the attic) will make an add-on wood burner difficult. Along with the increased insurance costs of an indoor wood burner.
This brings me to the outdoor wood burner. This seems to be a good choice to heat not only my home but also my detached 30x48 shop as well as provide hot water to my water heater. From the research I have done so far I understand I will need to run at least two water lines. One from the boiler to the house and one from the boiler to the shop.
My immediate question is, could one water line run from the furnace to the house service two electric furnaces? The furnaces are at opposite ends of the house. Ideally, I would like to run one line in, provide hot water to the water heater as well as to the one furnace located right above the water heater in the attic and then on to the second furnace through the attic. I do not know if the heat loos would be too high to do this or if i would need to set up an entire new loop for the second furnace.
I have not talked to a dealer yet as that is the plan this summer but I am starting to do the research now on what I think I might need as to not go blindly into the dealer.
Thank you again for any input.
Downside is when you get older (retire) you are STILL cutting wood!
