Below 265 SQ/FT 10' x 22' Project – ‘Officina di Attrezzi Veloce’
All workspaces below 265 squarefeet.
fourmotioneer
Ann Arbor, MI
Re: 10x22 Project - Operation 'Officina Desmo'
Great build here, and I like the Ducatis. I work on four-wheeled Italians here in Detroit area.
I just got a place where the existing garage has a similar setup. 3 cars worth of space but with a wall between the 20' wide section and the 12' wide section. Previous owner used the smaller space for motorcycles like you do. Unfortunately, I'm thinking that I'll need to remove that wall to make room for an Alfa or two.
T
Trapps
The Detroit Zoo
Thanks Graham! How's your GTV6 these days? I absolutely love those...
fourmotioneer
Ann Arbor, MI
I'm down to just the Milano! Sold the GTV6 to a buddy at work. Should be driving my Milano to work in Ferndale once this all blows over.
Dry clutches and desmo :bowdown:
nicholam77
Minneapolis, MN
After:
Looking so tidy. Your space always makes me wish I had done a similar thing with the HF chests.
:thumbup:
T
Trapps
The Detroit Zoo
:thumbup:
Lol, timely photos. I assure it is not always tidy!
I picked up some used flooring tiles at a solid bargain:
I now have some time on my exceedingly well washed hands and have started to lay them:
Not all were in perfect condition:
But a minute with a Dremel and the tabs can be cleaned up enough to sit properly. I figure if at least 3 tabs per side are good, the floor should remain stable in my non commercial environment.
Color is more variable than I'd like, but at $1 per tile + all the edging I'd need for free, I can't, won't complain. I'm using the Dremel to grind off the tabs. I am using a jig saw on a medium-slow speed with a fine cut wood blade to make shaped / larger cuts. So far so good.
mike93lx
Richmond, VA
Is the color variation just dirt? Have you tried cleaning them?
T
Trapps
The Detroit Zoo
Funny you should ask :thumbup:
About 75% dirt & 25% different lots is my completely unprofessional opinion...more on that below.
After installing the bulk of the remaining tiles I ended up here:
The edging strip was nearly a perfect fit to the garage door without trimming. :bounce:
I still have the strip down the east edge to do; each piece needs to be cut so I'll need some time.
Then I cleaned them in a 3 step process:
1. 409 and a scrub brush
2. Hot water and a scrub brush
3. Hot water and a clean rag (rinsed often)
The test:
And the result:
:beer:
T
Trapps
The Detroit Zoo
Sidebar
I am a fan of https://www.motoart.com/ and have toured their new (ish) facility once and the old one in El Segundo several times. Once I was fortunate enough to have a tour from one of the owners, Dave Hall. A super nice guy, he really provided an in depth look at the facility and product they had accumulated over the years - impressive is an understatement. His business card is laser cut aluminum:
10 years ago I bought a propeller off of eBay. It sat untouched for a long time. Lately I have begun the simple task of turning into a sort of conversation piece.
And the process so far...
Front as received:
Rear as received:
The ****:
I had to cut off the piston rod (had to look that one up); I used a Hackzall, then a Dremel followed by a random orbit sander w/ 220 and finally a wire wheel:
Then I began a series of sanding on the back side (the front remains un touched) 220, 320, Scotch-Brite:
So now we have to decide a couple of things:
1. Keep a matte finish or go full mirror polish?
2. Paint the tip a high contrast color. If yes which one?
Notes: the blade is pitted pretty good near the tip, but I don't think you see it from 5 feet away. Paint would certainly help here. It will live on the mantle so that's the color environment (natural black walnut and field stone).
Time to have a few cocktails and then have my wife tell me what I decided :lol:.
bj383ss
TX
That is going to be sweet. I vote for a bright color on the tip.
Bret
nicholam77
Minneapolis, MN
Damn, that looks cozy. :D
That mantel is really cool!
Garage floor tiles are looking good. I enjoyed the sidebar. Not that it really matters but my vote would be to keep the matte finish on the propeller v.s. polish to a shine. Is it going to stay on the mantel? I think a high-contrast color would be cool, not sure what to suggest, maybe just that it isn't too intense or in that room it might steal too much of your eye and put all the focus on it vs. just being interesting (if it was a really bright red for example). Maybe this is boring, but I think even an off-white could look good like the original?
Excited to see how it turns out whatever direction you choose.
T
Trapps
The Detroit Zoo
The mantle was a project for sure, but both the Mrs. and I are very happy with it.
Before:
At 10' long, 2" thick and ~14" tall, it is heavy. I built a fixture to hold it steady during mounting:
To mount it I stripped the face off of the original mantle, reinforced it with some heavy cabinet screws through to studs and then sunk some hefty lag screws into pre drilled holes from the back side.
On the prop, matte it is. Colors for tips include White, Yellow, Red, and perhaps a navy/cobalt blue (think WWII F4U Corsair). We'll mock them up and try before actual painting.
Title changed.
Thank you very much!
amkluttz
Concord, NC
I was going to say yellow or orange for the tip.
I'm liking the floor tiles in the garage. Did you ever finish the small strip closest to the house?
T
Trapps
The Detroit Zoo
Yellow is on the sort list. Not yet on the tiles, but I've been distracted...:)
The south end of the work bench was planned with an eye towards specific items and a way to preserve a bit of width in a narrow place. After I relocated the HF44's, I looked again at my plans and revised them. Originally I had planned on the Small Parts Storage Boxes (SPSB) being housed in a rack on casters. That would have meant a 'garage' for the cart would need to be located somewhere. I considered use and decided I'd really only be using them in close proximity to the garage, and if I needed to move I could take an insert or a whole box easily enough. Looking at a more dedicated layout (specific spaces for specific items - like the L-Boxxes) I decided to create a tall-ish cabinet at the end of the bench to mount the SPSBs in.
Before:
First step was to remove the 45° end and then extend the base:
I keep looking at track saws, and what other GJers are doing with and saying about them, but just cant go there on cost benefit analysis. Yet. So it's old school for me when ripping plywood:
I'm sticking with 23/32 BC ply over carefully selected lumber, treated on floor, non-treated above. I'm also adding jack studs at key points to manage the load. That Matco box weighs a ton and it's currently empty!
Here you can see where the SPSBs will go:
Imagine a similar but thinner wall on the left forming the cabinet. There will be 9 SPSBs from the bottom up, then 2 shelves above. The slides are 14" over-travel medium duty 100Lbs. from Rockler (currently back-ordered :sad: ) which means the drawers will pull out far enough to open the container lids completely without having to remove the SPSB from the slider drawers.
Hope all y'all are safe and well. :beer:
setup
Portugal
For years I wanted a wood propeller for my living room, but now I think I want a metal one! This looks so cool!!
Jeff Ivers
Oklahoma
That is a beautiful work space you have created. I really like the brick wall and wood ceiling. How do you access the trundles now? Didn't they roll out from behind the red tool boxes?
T
Trapps
The Detroit Zoo
Tool Trundles remain but will now be accessed only from the left side. My (as yet unproven :headscrat ) idea is to connect them like a train with a hook and eye configuration. What I have not determined yet is if I'll have to disconnect the 'Engine' and remove it to get the 'Caboose' out all the way. A bit of a PITA, but the items in the 'Caboose' will be infrequently used items so I cant imagine accessing it more than a handful of times a year.
I'll take pics once completed. :beer:
bikerneil
Carlsbad
Very nice space and great documentation along the way.
If you have any stubborn stains on that red floor, try a spray bottle with Purple Power. It is the BEST for cleaning that floor.
Keep up the great work!
GeddyT
Bellingham, WA
Just finished the whole thread (couldn't sleep last night for some reason), and I've been taking notes along the way:
1.) I have the same HF44 roller cab, and that's a really cool idea building them into a workbench. I'm always impressed with how people on this forum make use of every inch of space that they have. That exposed brick is awesome, too.
2.) Cool bikes! I've owned a few Ducatis that weren't my favorite, but I rode a friend's newer one, and it was amazing. They've really come a long way.
3.) Early in the thread, there's a Monster tank hanging from the wall. What was the plan with that?
4.) I have one of those DeWalt organizers, too, and each bin is filled with a different kind of leftover screw, just like yours. I hadn't thought of turning them into drawers, but I think I'm going to steal that idea from you.
5.) We have one shed-building trait in common: EZ-Up canopies to keep the rain out during construction!
Once I got three walls up, I took it further and covered the whole build site in a tarp. It was absolutely pouring down rain the entire weekend I built mine.
I've hated my shed since the day it arrived. I ordered a shed kit from Costco because I needed to get the shed up quickly and figured "kit" denoted a fast build. I quickly found out that it did anything but, and had I just built it from scratch, it would have been bigger, WAY more durable, cheaper, and probably have gone up quicker, too. I could frame a whole shed in less time than it took to unpack all of the boxes and figure out what was what. Anyway, I'm envious of how much bigger and nicer your shed is looking like it's going to be and regret not doing something similar!
6.) I, too, have a truck with a 6.5' bed. I've hauled 20' FJ fascia boards home in it without a trailer. That's what the back window is for!...
7.) Floor tile looks great. Question, though: How do you handle liquid spills with that kind of flooring? Seems like you wouldn't be able to just mop up.
Anyway, keep up the great work. I'll be following along.
T
Trapps
The Detroit Zoo
Thanks for props and the suggestion; I just ordered a gallon from Amazon for $16.27!
1.) I have the same HF44 roller cab, and that's a really cool idea building them into a workbench. I'm always impressed with how people on this forum make use of every inch of space that they have. That exposed brick is awesome, too. Several threads and builds here using HF44's built into a bench. Look for SteveO, Beepinajeep, Lucky13 and several others...I regret not building it with a toe kick, and I've revised the layout, but it's working well for me. I lack metal working tools and skills but would go that route for many things if possible.
2.) Cool bikes! I've owned a few Ducatis that weren't my favorite, but I rode a friend's newer one, and it was amazing. They've really come a long way. I have not had any bad experiences. Maintenance is key and can be costly compared to others options, but the performance is stunning and there is an emotional element that is very satisfying
3.) Early in the thread, there's a Monster tank hanging from the wall. What was the plan with that? It was a short lived artistic concept. I've since passed it on.
4.) I have one of those DeWalt organizers, too, and each bin is filled with a different kind of leftover screw, just like yours. I hadn't thought of turning them into drawers, but I think I'm going to steal that idea from you. In all fairness you'd be inspired by this thread cabinet for small parts storage cases which is where I stole, ah, was inspired, to design my set up
5.) We have one shed-building trait in common: EZ-Up canopies to keep the rain out during construction! anything to keep progress rolling when I'm in the zone, also works for snow:)
6.) I, too, have a truck with a 6.5' bed. I've hauled 20' FJ fascia boards home in it without a trailer. That's what the back window is for!... I've done this too.
7.) Floor tile looks great. Question, though: How do you handle liquid spills with that kind of flooring? Seems like you wouldn't be able to just mop up. My plan, ill conceived as it is, is to not spill anything.:lol:
Thanks for the positive comments!:beer:
grease_monkey
Mass.
Glad I found your thread! I'm getting some inspiration from your built-in work bench setup in a small garage. Looks like a really clean setup.
T
Trapps
The Detroit Zoo
Thanks grease_monkey!
Update finally:
The Tool Trundles are important for the ‘Space Planning & Utilization Directive’ in my shop, (220ft^2 or ~0.4m^2). 'SPUD' really means my goal is to find a balance of maximum space utilization against cost, simplicity and my skill set. I was able to develop the previously mentioned ‘train’ configuration which does embrace SPUD. The train is only accessible from the south side now, so only one handle. For the purpose of discussion, the larger trundle is the ‘engine’ and the smaller one is the ‘caboose.’
Some eye lag bolts and screw links act as the coupling device. I used 3 to ensure load was distributed as the weight is not insignificant once loaded up.
A rigid coupling would work better for entry as the eye/link combo flops around a bit:
Something I'll think about over time, and Scotch.:thumbup:
I also completed the ‘prototype’ phase of some L-Boxx Ports I’ve been planning for a while. They are not pretty or super-efficient, but they are functional. I do have a plan to redo them once I get a Router Table. Being honest, it’ll be some time as I often trade focus from one project to another once a certain level of functionality is obtained (ask my wife about bathroom trim; on second thought, please don’t :lol_hitti).
Bosch / Sortimo updated the design of the L-Boxxes recently. The new ones are 100% reverse compatible, so no real issues other than my Closeted OCD being triggered. New on the left, old on the right:
They also have the same exterior dimensions so I’m able to use the same sizing for the ports which was my biggest concern upon receipt of the newest Boxx. Here are the Boxxes in their ports:
Each of the upper L-Boxxes sits on a pair of clear pine 1x rails with a 45° mitre at the entrance. I have zero explanation for this. It just seemed aesthetically logical. :tard: The bottom L-Boxx simply sits on the plywood base. The 1x is stacked on 2x, and they are only ~14" deep, so sag should not be a concern. I also store less frequently used items behind the portal, in front of the Trundle Engine. That space is about 10" wide, so it is quite useful. Yes, I do have to remove those things (L-Boxxes and anything stored behind them) to access the Trundle Train (TT). But, since the TT is only needed infrequently it shouldn’t be a problem.
Completing this phase allowed me to move in the DeWalt Tough Boxes, freeing up even more floor space. I'm currently wrestling with the value of developing ports for those as well....
:beer:
bj383ss
TX
Man this is just fantastic. Someday I will get all my space used to this next level space usage you are achieving.
Bret
amkluttz
Concord, NC
The Bosch logo being in the opposite orientation would bother me more than the differences in the boxes. The nice thing is they aren't seen when they are stored.
I may have missed this but have you ever thought of finishing the raw wood of the work bench? I'm curious if you could get ebony stain to be dark enough to appear black instead of dark brown and still enjoy some of the grain in the wood. Minwax makes ebony in their Polyshades line which is supposedly a stain and poly all-in-one. That or painting them black, gray or white would fit nicely with the red.
mfg0772
Northeast CT
Just caught up on your thread. Your making good use of limited space. And love the shed. I'm looking to replace mine prefab shed in the future with something that can be both storage and pool changing area.
Keep on posting!
T
Trapps
The Detroit Zoo
Long term, all the raw wood will get a clear, matte polyurethane. The exposed 2x and ply edges will all be concealed with hardwood (probably maple) trim. The goal is to keep it on the bright side to help make the space 'feel' larger.
Moving on to three new projects before finishing the one you're on?
Never heard of it...
Amen to that... :beer:
Keep on posting!
It is a small space; I'd love to have a place big enough to have fully stocked separate a wood shop, a bike house/lounge AND park 3 cars inside. Not going to happen, so here I sit trying to fit the proverbial 10Lbs of S%$T in a 5Lb bag...
On the plus side this afternoon I was able to finally finish the floor tile!
Thanks all for the positive comments. I feel like I'm finally getting somewhere with this project. And, with weather breaking finally here in Michigan, I can get back to the shed which really only needs a roof (currently tarped), siding and electrical.
mike93lx
Richmond, VA
It is amazing how good it feels to get a space clean and organized.
My garage is an absolute **** show right now and I need to fix that. No time to build benches and cabinets, so I think I need to **** it up and buy something like a new age setup
nicholam77
Minneapolis, MN
You are not alone! I've left unfinished areas of trim in my house, I'll admit (this is a safe space, right?), for almost a year just because every time I had an opportunity, there was something else more exciting to work on.
I think the L-Boxx ports look great. Nice and tidy.
Woah, that is almost worse than the Systainer redesign! Are there functional differences or did they just switch up the looks for no reason? At least the fronts look pretty similar. It would bother my "OCD", too, but at the end of the day it's a tool box and at least it's the same colors.
If you're looking for L-Boxx's -- this deal is sold out at the moment, but if you're interested maybe keep an eye on this? Great price for an L-Boxx 4 + an otherwise quite expensive Bosch anti-static vacuum hose.
:beer:
T
Trapps
The Detroit Zoo
Looking really great. Such a cool space and so well designed and implemented!
m.
Thanks for the kind words. Learning as I go here which means revisions and changes, but it's definitely moving in a direction I am happy with!
I do enjoy having a place for every thing and every thing in its place. I have not posted pics of the craziness but rest assured, there are days I walk in and have to clean up just to see the mess I've created.
:beer:
The biggest difference is that the connection point was moved from the sides of the box to the lid. This allows a box to be opened even if another is mated to its top. Not sure I would ever do this, unless perhaps the top box was quite light. It does now place the load on the hinges and hasps instead of the 'frame' of the box itself. Some reviewers say the structure of the new box in the corners is not as structurally sound as the earlier generation. I have yet to see a difference, but I'm still limited in use with the new one. I've had it for a few weeks now and I'm done losing sleep over it. Almost. :(
Cheers all!
T
Trapps
The Detroit Zoo
I've been busy. At home, at work and finally, in the ongoing, evolving and slooooooowly progressing project that is my garage.
I've been planning the small parts storage boxes for a while now (see post #33 from Dec/18). Garage Journal has provided so much inspiration. I had time to plan as I added parts over time. I wanted something sturdy as the boxes get heavy (I weighed the heaviest and it's tipping in at just over 22Lbs.). There are 9 storage boxes, each riding on a fairly solid drawer. There is a decent sized cubby at the top and some storage potential behind the drawers I have not yet planned out.
Before:
After:
Over Travel slides allow the lids to fully open and stay up while I am digging...
Drawer bottoms are 1/2" baltic birch, rails are poplar. Screwed and glued.
I used Titebond III and some 1.25" construction screws, each with a pilot hole and countersunk.
Slides are 14" Over travel Medium Duty units from Centerline (sourced from Rockler)
I grooved the rails to accept 'flanges' on the sides of the DeWalt Deep Pro Organizers
I cut the 'grooves' with a mitre saw. I realized afterwards I could have set a stop to control depth. So, some of the cuts are not perfect. For depth or placement. A jig would have helped here...Still they work well, hold the boxes in place and release easily if I want to take it with me.
The handles are situated so that you never actually touch the drawers. Still, all the rough and sharp edges got a once over with 150 grit.
Thanks to all who posted and inspired! I love this place! :beer:
mike93lx
Richmond, VA
Looks great. My setup is much simpler, but adding storage for those parts bins has been super helpful in my garage. More would be great.
It's well worth a couple hundred bucks for the organization it all offers
T
Trapps
The Detroit Zoo
Got the place tidied up enough so that I do not go too far into my OCD stress zone when I walk in. I completely reorganized the inside of the black storage cabinet to accommodate the router table.
I can now return to other unfinished projects, namely, the shed. I borrowed that big flatbed trailer again to pick up the roofing for the shed. Pro Rib from Menards, 14' off the shelf in Charcoal Grey. Pretty cool they stock this stuff. J-Channel too.
Note the saw chips on the ground. I dropped a couple of large-ish (55' & 60') pine trees and ripped out a section of Buckthorn about 15' deep and x 75' long across the back of the lot. Enough debris to fill a 30 yard roll off after I sliced and diced the contents 11 times by climbing into the container, standing on top of the pile and carving it up with the small saw.
The debris pile:
The roll off at about 1/3 full:
Missed my targets by 6":
The larger pine:
The noisy bits (I frikin' love these saws! :bounce: ):
Gratuitous action shot:
:beer:
nicholam77
Minneapolis, MN
The workshop is looking really, really tidy. Great job on those organizer boxes. Seeing a bunch of uniform built-in boxes on drawer slides makes me very happy for some reason. Smart with the grooves, too.
Looking forward to more progress on the shed!
T
Trapps
The Detroit Zoo
Great job!
Thanks!!!
Thanks Mike! Small space + Marginal (overbearing?) OCD means it must be organized in there. I lived with the boxes simply stacked for 9+ months. That took up 1/2 the physical space, but was a PITA if I needed to access the 3rd box down. In this case I traded space for functionality.
I have plans, concepts really, still floating around my head, to make it better with regard to the L-Boxx ports.
Thanks Nick! I am very happy with the Small Parts Storage Box rig. Tidy is easy. Organized is what takes time...Now reloading the HF44 drawers to improve efficiency. Shed materials are accumulating on site so that when the time becomes available I can move quickly.
:beer:
