Bigblue&Goldie
This is a long overdue build thread of my 2”x48” belt grinder that I completed a couple of months ago. I don’t post a lot of my projects, but I feel I owe the board a good write up on this one as a lot of my design work was influenced through other member’s build threads and advice that I received from various members during the process. If you look at the numerous build threads you will see that every belt grinder is unique in its own way and there’s valuable input in each of them.
Typically you will see 4 wheel 2”x72” builds that are popular with the knife makers, but not too many “general fabrication” builds. I’m not a knife maker and I wanted something with a smaller footprint, so I decided that a 2 wheel 2”x48” that I could mount to my fab table would be ideal for my needs. Ideally I’d shell out the coin for a Burr King, but that’s down the road when I have a shop that justifies it. In my research I found this design online that supposedly is very similar to one that Delta made back in the day (I’ve never seen one). I thought it was a pretty sound design, so I modeled mine after it.
Knowing I wanted max Surface Feet Per Minute (SFPM) I could get out of a direct driven 2 wheel grinder I settled on the biggest drive wheel that I could find (6”) and a (4”) tracking wheel to go along with it. I then took these sizes along with the 48” belt length and plugged them into this calculator to find out what my pulley separation needed to be (16.12”). With this information I started drawing the various components in Fusion 360. My goal was to have the belt be as vertical as possible at tension. On a typical 4 wheel knife making grinder this is often achieved with a “D” shaped palten, but it’s a little bit trickier on a 2 wheel grinder where you don’t have much in the way of adjustment.
https://www.sudenga.com/practical-applications/figuring-belt-lengths-and-distance-between-pulleys
One thing that I should mention is I designed this whole belt grinder with no physical parts in hand, so if things look wonky that is likely why. I was able to get a CAD file for the motor from McMaster Carr, but the other items (including the wheels) were kinda guestimates. With parts in hand I would’ve made some small changes that I will talk about as things progress.
