_brian_
What is the opinion of those here on greasing parts that do not have a zerk fitting, or other way of adding grease?
On such parts, I see three options. You can obviously treat it as disposable and not worry on grease. You start to see issues, you replace it. The other side seems to have the other two options. First, you can drill and install a zerk fitting or you can use one of those needle grease adapters to poke a small hole in the boot and insert grease.
Personally I see all three options as less than ideal. Factory under-greasing is quite common and can lead to replacing otherwise good parts. If you poke a hole in the boot, no matter how small, you are disrupting the integrity of said boot. IF you drill and tap in a zerk fitting, you risk damage from the drilling process as well as metal shavings in the joint.
Obviously buying a part with a zerk is ideal, but is not always possible. So if you are stuck with a non-greasable part for whatever reason, what is the best course of action?
