Push Trimmer
Whiskeymike
Austin, TX
I have a 400' fence and brush around a small pond that I'd like keep clean. I'm wondering how useful a string push trimmer is. I have a gas trimmer, and it's pretty tiring after trimming 6 acres, the fence line, trees, and I don't even mess with the pond any more.
From the reading I've done, complaints are that the string breaks often and you have to stop and restring. With the gas trimmer I have, it has 10' that autofeeds, so not sure if that ends up trumping the push trimmer.
Can you mount a blade to push trimmers like you can the hand held trimmer to cut larger brush?
Any recommended models?
tymbo
West Chicago
I have a DR trimmer. I use it exclusively with a 12" "beaver blade" (chain saw chain wrapped around the disc) cuts up to about 3" diameter stuff.
lolaetype
North Western Arkansas
I've got one, made by Swisher. Works well. Takes 0.155" line. I buy the line in rolls rather than the tubes of precut lengths. It's much cheaper that way.
Early on I tried substituting multi strand steel cable figuring that would last much longer than the nylon line. Surprisingly it didn't last much longer. .
MACbox
TX
Submerging your trimmer line in water for several days will keep it more “flexible”. Sounds strange, but it’s true.
I have a Poulan Pro. Works well, but the rear wheels are slightly smaller than some other makes. Makes it get stuck in holes more easily. I do like that it has a “brake” that does NOT kill the engine when I release the handle. The trimmer head stops, but the motor keeps running.
Saves me lots of pulling on the starter rope..
MACbox
TX
The Echo Bearcat has a blade attachment. Some of the DR models may, also. The rest seem to be string trimmer only.
Ton ton
Page County,VA
My Husqavarna has a brake as well.
MACbox
TX
Yeah, I think the Poulan Pro and Husqy were the same unit. Looks like they may now be discontinued. The DR “Premier” seems to have that same feature. Their cheaper one doesn’t.
I don’t know much about the Cub Cadet, Swisher, or Remington.
SARG
Northeast
I found they are useful for a specific chore such as around a pond....... but beyond that the hand carried jobs are preferred.
I sold my DR last year when the property with the ponds was gone.
lolaetype
My swisher doesn't have the brake. Release the handle and the engine quits.
