Today I...
Installed the door sweep.
Cut up the remaining unistrut.
And mounted the unistrut to studs at the ceiling as evenly as I could all the way around the shop.
I also designed my system today and priced out all the parts. Water trap is already ordered. I have my vertical 3/4” black pipe in place with 1/2” drip leg.
I will tie into the black pipe with a 1/2” copper loop around the entire edge of ceiling with ball valves and unions centered on the E and W walls. There will be 3 threaded Tee’s on the N and S walls and 2 threaded Tee’s on the E and W walls totaling 10 potential drop locations.
I’ll initially plumb a hose reel roughly centered in the shop, the plasma cutter, and a blow off nozzle on a coil drop. I’ll plug the remaining Tee’s until needed.
