Need a small cheap compressor
MushCreek
Upstate South Carolina
Let me repeat- small and cheap! I know someone is gonna recommend a 25 hp screw-type compressor. I need a small, cheap one- maybe $150, tops. My nice little Emglo rusted out, and it weighed a ton anyway. I have a big stationary one in the shop. I need something I can wheel or carry up to the house for airing tires and shooting finish nails. I've been looking at used ones, but they're either old and abused, or close to the price of a new one, so I'd rather just get a new one and get a warranty. Very light homeowner usage.
Something like this?
https://www.harborfreight.com/merch...-hand-carry-jobsite-air-compressor-56829.html
Currently $119, and seems to have good reviews.
jg4660
Western NY
The HF one you have linked will work fine, even there cheap one for $40 if you only want to fill tires and finish nails. I use the HF $40 one to winterize my camper by blowing out the water lines...its slow but gets the job done.
510ebl
Southern New Jersey
If you are walking around with it and don’t need a lot of tank capacity, I would buy a single hot ********* with the compressor mounted over the single tank.
The wider pancake and “double” tank type have to be held off to the side further (which is tougher on my back) or they smack me in the knee as I walk.
Not saying this is a good choice (at .36 cfm), but an example of the type I mean:
https://www.homedepot.com/p/Campbell-Hausfeld-3-Gal-Horizontal-Air-Compressor-FP209499AV/203002168
2c
unslow1
Illinois
Just get one of the HF little $40 ones. I have several air compressors but I rarely fire them up. That little HF one does just fine most of the time. I know a few guys that use them for trim nailers.
DFB
Southern VT/Western Mass
Ya very similar to my old Craftsman Industrial Series pancake compressor 3.3 @ 90psi and that I have had for well over 20 years run hard and put away wet. Plus the tank is slightly larger.
Sure it be one I consider if I was to replace what I have anytime soon. I have been eyeing the 1 or two gallon Fortress for a while now though I been hoping for small cordless on my battery platform so I don't have to lug any corded tank unit for the little jobs (or buy an 18ga cordless to supplement my 16ga)
Mush I'm behind ya on that one for the sale price no brainer in my book. My Craftsman was over $200 all those years ago. See how much extended warranty is maybe 2 or 3yr is for piece of mind.
What I find amazing about some of the newer small compressor motors is the amperage draw. and for like remote invertor use might be something to consider. My old black Craftsman Industrial pulls a solid 15A pops breakers all the time :lol: I see that 6 gal Fortress is 12A
Those cheapest Frieght ones are wicked low amp. I pitched a few under my summer tool tent and they were popular with people but I couldn't say how reliable they may or how long they would last under any serious use, I also Notice the almost $55 reg price now... were once like $39 and could do 20% off too :pimpflash
goblue1998
Washington Michigan
tarbellb
Oregon
Same ^^^
Both Husky and HF sell a very nice looking low volume compact compressors. I just sold my 15yr old leaky Porter Cable pancake for pennies, happy to do it.
rharrison8
Indy
bpjr
Florida east coast
How do those oilless pumps hold up compared to oil ones. Things have probably changed but the oilless one I had yrs back lost compression real fast just for diy home use. I took it apart and found a single ring made of a nylon type material and solid piece without expansion gap.
bctexas
Aubrey, TX
Hi Mushcreek,
I bought a 4hp Sears compressor around 1975. When the tank rusted out, I went to the local compressor repair/sales shop, and they sold me a lightly used tank for not a lot of $ - don't remember exactly but it wasn't much. I had to drill a couple of holes to mount my Sears motor and compressor, but I am still using it to this day. Maybe not the solution you asked for, but if your motor and compressor are ok it might be a cost effective solution....
MushCreek
A follow-up. I bought the little Craftsman pancake unit on sale at Lowe's for a C-note. Works great for my finish nailer. I can drive quite a few nails before it cycles on, and it doesn't take long to refill. The noise isn't too bad, and it's easy to carry, which is the point of the thing. My one complaint is that it walks across the floor when it's running. In the shop, I put it on a rubber floor mat, which keeps it from walking, and quiets it a bit.
I'm not sure what to do with my old Emglo wheelbarrow unit. The tank rusted through. The pump is good, as is the motor. Considering I pain $100 for it, and built my entire house with it, it doesn't owe me anything. I need the motor for my bandsaw, so I guess I'll see if I can get a couple bucks for the pump. Should be worth something to someone.
