Between 485 & 705 SQ/FT Mid-Century Moto Mecca Makeover
Vertigo Cycles
Portland, OR
I made the initial couplings with 303 stainless and discovered several things: 303 rusts and my fits weren't tight enough. The joint leaked or else Scotts boot melted on the pipe. Not sure which. I was going to weld this joint as well but decided to leave it and perhaps try sealing it with some high temp ATV.
I can't recall all the stainless alloys but I do know that some of them benefit from passivation after welding or they're prone to rusting. The bike brand, Independent Fabrication had this problem on stainless frames about a decade ago. I believe it caused them to drop stainless as an option. Is it only the weld that's rusty or is it happening on other parts of the pipes?
This new bracket worked out well. I'm using Jody's rule of 33 for stainless. I changed the pulse to 1pps and that seems to help force me to keep up the speed. I'm discovering that speed is the missing ingredient to my welding.
Gregor
Did you find that you had to crank up your amperage and change your on-time and BG amps when you changed your pulse rate?
jdp993
Most stainless alloys benefit from passivation after welding. There are a number of chemical products you can get for passivation or you send it out to have the whole piece done. The ultimate goal is to restore a uniform layer of chromium oxide on the surface which is what gives stainless its corrosion resistance.
I have also found the shielding the back side of the weld is important. Otherwise you get this nasty brown oxide on the back side of the welding which is a site for future corrosion. I found this to be particularly true for exhaust pipes.
Very much enjoying the you tube videos!
sakurama
Portland - the cool one.
I raced shifter karts about 10 years ago and while racing at NHIS, going through Turn 3 there was some nasty woofs right on the racing line. When I hit those bumps. it would cause my foot on the throttle to bounce causing inconsistent throttle modulation which would upset the kart entirely and slow me down. Someone noted the springs on the pedal were too soft. As I started adding them, I noticed a HUGE improvement in throttle control.
Same thing would apply in your case.
In fact the reason that I decided to use exhaust springs for the lever was so that I could double them up if needed. Right now, after repositioning the tab for the master, the spring is very strong which I like.
And, I know all those bumps on T3 at Loudon. I hated T3 for that reason and also because it was a right uphill and then slightly off camber. Nothing to like. Although it was the location of a very funny story from when I was racing...
The AMA national was there and we were sharing the track on an open practice. I saw Aaron Yates coming out of the pits as I went by on my TZ250. I had been getting very quick but fully expected him to come around me within a turn or two. For three laps he stayed on my wheel and I rode as hard as I ever had. Visions of a factory ride were in my head - I was keeping an AMA pro behind me! I had truly arrived! I was FAST!
Then, as we exited T3 and headed up the hill, he sailed around me on the outside, his back tire smoking and kicked out and at the same time he looked over his shoulder at me and shook his head. In pity I guess.
I pitted in and didn't go back out for the rest of the day. I was mortified.
So, yeah. Turn 3.
Nice work on the video Man
What kind of equipment are you using for video making? I bet you have some good stuff being a pro photographer. Love to see more videos from your workshop and house.
And by the way what is that "Gregor and kitten" video what is making girls wet in your Youtube comment section. Do you have a secret Youtube star past:bounce:
Just an iPhone for the moment. But the new one! Luckily I actually bought a new laptop right before all this happened and while it's not a blazing work station it's quick enough. And I sold both my other computers for almost the price. In fact I'm surprised that people are still buying but I'm unloading a lot of stuff on ebay right now - much like every spring.
Oh, and the kitten thing? Many, many years ago when YouTube was starting I had a new kitten and it loved water. I'd told my client about it and they didn't believe me so I shot a video on my little point and shoot of me holding the cat in the shower. They thought that was hysterical and my editor said I should put it on YouTube. It seemed like a really bad idea and I was single so I did it. Within a month it had like a million views and I got marriage proposals, a offers of dates and an invitation to be on Animal Planet or some other TV show. I ignored it all until the guys I raced with at the track somehow found it and that was the last straw. I pulled it down.
I coulda been living on those royalties!
No, the 303 didn't even get welded which is the strange thing. Supposedly it could be sulfides blooming from water exposure. Anyway, I replaced it with 304 then an aluminum one for the back. Eliminating one slip fit by welding the step on the mid tube seems to have tightened the joint up.
And yes, I had to turn the amps way up so it was like 80-90 peak but I wasn't using them all.
Also, Episodes 3 and 4 uploaded.
Gregor
MotoDave
Ventura, CA
Ask a subsea equipment engineer how stainless stainless steel really is.
There's a reason it's called corrosion resistant steel in the engineering trades generally.
A35Plt
Suwanee, Ga Europe and SW Asia
Subscribed.
May want to leave off the glasses when doing video, the light reflecting off them is weird and distracting.
You also don't sound at all like what I expected. I was expecting more of a James Earl Jones voice LOL.
sakurama
Subscribed.
Wait, you didn't like the batman voice? Oh, right, we haven't gotten there...
G
kjdhawkhill
Flyover state #4
I'm not a motorcycle guy, and I'm not a jeep/4x4 either. BUT During this shelter-in-place I've gone on a deep dive on Jeeps on YouTube, and I'll happily watch your motorcycle projects, too. Having the video and 50 words is probably worth 10,000 words here as far as my understanding of the physics you're working through.
Production quality of the videos seems pretty good, and you've got a good lead-in/intro to build the theme/brand. I agree with the episode length comment above, 8-13 minutes seems like a sweet spot for many channels.
I definitely read your stuff here for the house, shop and van, but I stayed on board with the motorcycles because of the passion you put into them - even the race (not show) bike.
zmotorsports
Northern Utah
Anyone else learn a new word today?...
Trust me in the industrial refrigeration world, passivation is almost a 4 letter word.:lol_hitti It's one of those necessary evils. When done correctly and monitored properly the outcome is perfect, HOWEVER, if not done correctly and levels not observed during the passivation process the life of a condenser is cut tremendously and you're in for nothing but headaches.
mfg0772
Northeast CT
Long time follower, first time poster here but just wanted to add that the the videos add a another great level to the already awesome thread. And the production value is fantastic. I'm hooked.
sakurama
There's a lot of good videos on stainless passivation. My favorites are the Tig Brush ones because they seem like magic.
Okay, video 5 is up. You guys are getting spoiled with a video everyday and in four more I'm going to be out and have to start to make them myself. Then you'll be sorry.
For now:
Gregor
Bakafish
Tokyo
I'm worried about some of the copyrighted music that shows up in the background (the radio you are listening to in the second EP, and the super litigious Queen snippet.) From what I have seen from the aftermath of many of my favorite talents getting hammered by this, the YouTube the music rights holders are super aggressive about usage (even when it would otherwise seem fair use) and their tools catch almost subliminal signals. You may be flying under the radar now, but it may bite you at exactly the wrong time when something you have starts to gain serious traction with views. When a video goes down, all those likes, comments and views go with it, rereleasing a cleansed version later will probably be suboptimal.
I'm sure you are aware of all of this, but I mention it just in case as I really want you to succeed there.
zmotorsports
Northern Utah
I had a couple of my videos removed and my channel locked when I first started because I had music playing in the background while working in the shop and evidently it was an infringement of some kind. It definitely wasn't intentional, I just wasn't thinking legal, I was thinking work mode. Now I just make sure to turn the radio off when filming.
Not sure how closely they monitor it but mine was caught very early on after only 2 or 3 shop videos.
fartymarty
Fort Worth
Very good point!
Now I'm totally pulling this from my nether regions, but I think that if you mention it in the video or give info in the credits about the music, the artists names, and the availability ("available from such n such label") you may be forgiven for it's usage. Your video becomes more free advertising rather than infringement. Just a thought, perhaps a good one, perhaps not.
fartymarty
Fort Worth
I've enjoyed all the videos, very well done. I liked all of them, but personal highlights for me: Drill chatter/ Chewbacca association, Google translate pause and read was fun, anytime your sister was in the shot. (sorry, any anonymous internet reference to one's sister can be creepy, not meant that way by me. It's just that she is so much better looking than you. :lol_hitti )
sakurama
Yes, good points all. I'm going to blame any music infringement on my sister because she's much better looking than me. Again, I never anticipated putting this on YouTube - I was just shooting IG stories so there was no thought out plan. I let Jesse do the editing and he does this for a living so I'm trusting his judgement if something in the background is an infringement. I always listen to music in the shop - it's one of the most essential tools in my opinion but it's not good for video for numerous reasons. I am now turning it off when I shoot video. Mostly because I like the sounds of machining and think that should play a bigger roll. My goal is to eventually make the video look like my still photos and the sound should be a part of that feel.
Also, I have an epidemic sound account so the music I use is licensed but Jesse picked that music and I think he did a good job. I find it very difficult to find music I like on that service or in general. I sort of wish it worked better even though there's many ways to sort and find music - it isn't really based on "liking" music as much as mood, tempo, length and all sorts of other metrics.
Anyway. I'm going to try to shoot something with the real gear this week or weekend - I've lost track of what day it is. Other than Friday. Pizza always comes first. I'll have no background music. I'll just overlay a purr track from my cat.
G
douglawrence42
Evington, Virginia
Pizza would be a great “try out the full gear” video, and if you’re going to do varied content all on the same channel (a mistake for most, I think the right call for you), that would go ahead and set the algorithm into deep thought regarding what the heck you are doing. Personally, it would save me a lot of time flipping through a million posts in this thread to find the recipe.
GeddyT
Bellingham, WA
I'm no Hasselblad master or pro photographer doing work for Oprah, just a geek that's never found a complex device I can't get hooked on. Cameras were no different. I never really got into photography at all until I owned my first "real" camera, purchased just before my son was born for the purpose of capturing memories during his early years.
The camera was a Panasonic GH2, and I still regard it as perhaps the finest hybrid photo/video camera relative to its peers at the time ever made. Thanks to this camera, I got just as hooked on video as I did stills. Leased a Creative Cloud suite, started teaching myself Lightroom, Premiere, After Effects, etc. At first, I was really excited about the process, so every birth, trip to the zoo, etc. resulted in a long, heavily edited little movie set to carefully chosen background music, etc. Eventually (after many years and hundreds and hundreds of hours on the editing station), the novelty wore off, I changed positions at work and got way more busy, and my video editing got far more "get to the point."
I bring this all up because your point about the difficulty in choosing music rings so true to me. No matter how many times it happened, it continued to amaze me that--100% of the time--I spent more time choosing music than I did cutting and editing the video. My workflow quickened when I started editing the video to the music clips instead of matching music to video. Moving and slicing video clips was WAY faster than finding a song or section of a song that's within a few seconds of 2:34, doesn't have distracting vocals, and fits the theme of the video. And that's even when you have no concern for copyright, as I never planned on publicly posting any of them.
I feel for you, but I know you'll get it figured out. The content you've been putting out so far has been top notch, as I think all of us expected.
Geezershop
Lubbock, Texas
Enjoyed the videos as I have the GJ thread. I do hope you will slow it down some and show more details of the process. Just my 2 cents. :)
JasonJ
Las Vegas
I enjoy the videos but the endings.... I am left wondering if my internet froze up for a split second. Do a sign off of some kind. :)
Overall I like your videos, I have no advice, as you will find your way and create what you seem is right. People will either subscribe or they won't, but I bet you will be surprised on your youtube following as time goes on.
bdbecker
Iowa
Took the words right out of my mouth...
The end of the videos would be my only critique as well. Something as simple as a black screen your "G" logo for a second or two to signal the end of the video is all that would be needed.
Otherwise I'm totally digging what you are doing. Keep at it, you're already off to a great start. There are going to be some hits and some misses, the main thing is that you keep at it and you will find your own style and voice. I can see it already - someday I'll read a post on some random thread where someone says "Man, I'd really like to make youtube videos as good as that Gregor Halenda guy..."
Choirboy
SE Iowa
It will be like this "Hey guys, I'm new here. I'm starting this thread as a way to get some feedback on my new youtube channel. I mean, I'd like to get to Gregor Halenda level at some point, since he is the gold standard, but right now I'm just getting started..."
Videos are looking great! Your work is paying off in the quality!
H1Pete
The videos are great so far. Already learned a few things watching them. I lost the chuck key to my drill press years ago and have never found one that’s a good fit. It never occurred to me to replace the chuck until you mentioned a keyless chuck. I smacked myself on that one, thanks (have one on order now).
Only one complaint on the videos, you’re going to run out of them and you’ve got us addicted already. Outstanding work Gregor.
lilscorpion
Colorado
Gregor - that caliper trick is BOSS!!! That one was four gold star worthy. That one tip is a game changer. Can not believe I never thought I’d that.
fartymarty
Fort Worth
I had to go watch them all again (still good), but I'm retired and had time. For those of you that don't have time, Episode 5 @ 3:45.
I had absorbed the tip the first time I watched it, but when lilscorp' mentioned it, I thought: I don't remember any brake caliper tip. :headscrat :lol:
Yes, it is a good one! :thumbup:
jake28
SF, CA
@sakurama Like many others who have posted, I'm a long time follower of your work and first time poster. I had a photo (admittedly stolen)* of the cafe racer beemer on my wall all through college, two recessions ago. I followed the construction of the 950 ADV bike when I should have been studying, and have periodically checked this thread for escape and inspiration.
I reread the thread from the start over the last week. Much of your inspiration is still simmering, like sautéed garlic chunks, just beneath the surface. A few choices things I've written down into a sort of recipe to riff on. Your photos, words, and projects have always provided me with a model of how to be a studious generalist, devout dabbler, and focused pursuer of passion projects. Thank you for being the standard-bearer of traits and skills rarely celebrated any more.
*In the spirit of giving back,
- to you and the rest of the crew like @lilscorpion and @vertigocycles that feel as I've gotten to know well via a concentrated reading, I look forward to sharing a keyhole look into the construction and outfitting of my dream shop and home in San Francisco in the coming months.
- Swag, Sak - if you feel motivated to whip up some to shirt designs, I'll join the list of buyers. "Mofk'n pancakes and a vector logo" has a nice ring to it. Buying a T is the least I can do for enjoying the Team Incomplete photo on my wall for years.
- Youtube, I'm proud to be in the first 1k followers.
One video tool you might like is the DJI Oslo Pocket
https://store.dji.com/product/osmo-pocket?gclid=CjwKCAjw4KD0BRBUEiwA7MFNTbwJ00K-W_g_lJ3Y8iv7cD7A14yeIEyIpP0XCVyGFaOK-Lm5S5hszhoC4LoQAvD_BwE&vid=48141"
It's small, cheap, shoots 4K, interfaces with an iPhone or Android, and can easily set up gimbal-based pans, time-lapses and neat visual tricks. And you can edit in the app for quick uploads.
Always a fan,
jake
GeddyT
Bellingham, WA
Gregor, THANK YOU!
Want to know what I learned from your videos today? Google Translate. Holy ****, that's amazing! I just bought an old French universal mill, and the only instruction manual I can find is in French. I've spent a lot of time today using Google Translate to learn what grease and oil I need to buy and where to put it. Awesome!
Patreon, T-shirts, stickers: DO IT! (my vote is still for "Mission Creep.")
Vertigo Cycles
Portland, OR
Gregor, you might recall a few years ago I asked you, a bit exasperated about how to get square cuts from the MFT. I've been making a lot of cabinets lately and discovered that if I put my dogs behind the back rail, and snug the rail to them as I tighten it up and then square my track, my cuts will stay square all day. I realized that the adjustable angle doo-dad that holds the rail wiggles a little bit I push my material against it to square it up. My pieces would be 1-2mm out over their length. Now most of them are within 0.25 - 0.5mm. Eventually, I'll machine something to hold the rail and will save the adjustable part for if I ever need to set an angle.
This is probably well known, but it just hit me an hour ago and I wish I realized much sooner...the vacuum with a large systainer on top is the same height as the MFT table top. I've been supporting long pieces by hand like a jerk for years as I don't have space to store an aux stand anywhere.
Also, the InstaRail XL square is a really nice thing to have, as are the Seneca Woodworking Parallels. Definitely items I wish I bought much sooner.
sakurama
Okay, I spent 3 hours trying to figure out how to put a logo at the end of the video. I am really looking forward to the day when editing is second nature the same way photoshop is.
Wow, hard to believe I could teach you anything. But, yeah, it's one of my favorite tricks.
As an aside I'm trying to pull as much as I can from your thread and start to organize my tooling. See next post.
- Youtube, I'm the first 1k followers. One video tool you might like is the DJI Pocket
Thanks - it's nice to hear that. I hope I can repeat the success of the those earlier bikes.
It's funny you posted about the Osmo - I'd seen it and dismissed it but then I've been looking at using my GoPro's and I'm really bugged by how wide angle they are. They just have such a "look" to them that it kind of bugs me. I think they can have uses I just think they're limited to B-roll type stuff. But that little guy might be a good idea. It could get me to stop using my phone and maybe be an intermediate step to the full camera/gimbal setup.
Which I'm going to try this week...
Alright, in the mean time I can post a small update... Episode 7 is up now:
Gregor
sakurama
So if you ever read Lil Scorpion's original thread - and I'm guessing you have if you've followed for any length of time - there's a boat load of great ideas there. It's certainly where I picked up the whole "french cleat" thing, or, as several snarky commenters to my Instagram mentioned, "Freedom Cleats". Rich.
But first I needed to address my stock storage shelf...
I just checked the date and I built this in 2014 - 6 years ago. It's so old it was from when I shot verticals. That's old. Anyway, it worked well when it was hung on the wall but I never anticipated putting so much weight on it. In the end, when Lara and I pulled it down to put the Bridgeport in, it had over 300lbs on one french cleat that just spanned two studs. But it was pulling out and after the Bridgeport went in it sat on the floor. Being hard to sweep around.
I have decided I no longer like pocket screws. That's what was holding the french cleat in the cabinet. They didn't fail but were on their way. Perhaps it's not fair. They did hold the whole time but, nonetheless, I declare our relationship over. For the moment. For things in the shop.
Same with edge banding. I never want to do that again. Yuck.
So I just ran the Festool track saw over the cabinet after pulling the shelves. Cut it right in two. I took it apart and used the band saw to cut the notches for the stretchers that would hold the load.
Considered putting it on a french cleat that stretched to three studs but in the end decided that if I didn't move the first one for 6 years I could probably take the chance and just screw this new one into the wall. The space between them is so that I could get their inner dimensions wide enough that the stretchers would stretch to catch three studs.
My goal was to get the material off the floor. I make a real effort, inspired by Scott Kolb, to clean the shop every night unless I'm really in the middle of something. And I hate sweeping around things. so if I can get it off the ground I can sweep under it easily. I am a little embarrassed at how bad this looks because I just used the rest of a left over sheet of pre-fin shop grade plywood. The last that I had left over. I didn't edge band it or even sand or finish the edges and they're not even cut perfectly. All in all a hot mess. Nonetheless I'm okay with it for now. It's burly and at the right height and the center section is either going to be for small sheet stock scraps or the 5c collet closer.
Still undecided.
But, driven by the memory of Lil Scorpion's original thread where he put french cleats, er, Freedom Cleats behind his bench I decided to do the same thing only a little different. Since the lathe was already kicking up a stripe on the wall I decided instead of doing the lattice I would do a full 11" of plywood that would go across the length of the cabinets and have a single cleat. I was using up the last of the shop grade.
With the shop grade ply out of my life I set about making the first thing to hang on the cleat - a collet rack from baltic birch. I still had two full sheets left over from the back room and we'd actually already finished them. And by "we" I mean Lara actually finished them. Thanks Lara! Hope you come back to Oregon soon. And learn to post here.
I did consider rigging this up in the mill and using the DRO to drill the holes but I just didn't want to cover the mill in sawdust. So I went old school - pencil and square. Interestingly this is the sort of thing I know I would have botched many years ago but I have come to terms with a new level of precision this past year. I don't know which came first but somehow I recalibrated myself to just go another level in. I don't know if I ever mentioned it but last year I finally made the rank of "High Master" in pistol shooting - the highest rank there is and with an average score of 97%. I just stopped accepting "10's" and decided to focus on the X and I got more 10's. So I've stopped accepting mm's and am trying to split lines and account for pencil widths.
It just narrows the window down. Nothing is perfect but it's closer.
All that to say that the grid turned out pretty close to perfect. I really enjoyed trying to hit the bullseye with the forstner bit's tiny triangle point - exactly. Later tonight I'm going to edit some iphone video for my IG story on this. It's sort of a way of testing things.
Also, I love baltic birch. I know I've said it before but just slap me if I ever buy shop grade again for anything.
So I've tried making holders in steel or aluminum, my thinking that I'm in a metal shop and that's what I should do, but it never seems to sit as well with me as when I use wood. Something about the softness of wood holding hard metal tooling seems really right to me. I have decided I love the dichotomy and I'm going to make all holders and racks from baltic birch going forward. This is my test part - the proof of concept.
I have only 55 collets right now but I made this to hold 70. Some are oversize and I'll probably get a few more down the road. I was going to cut it at the bottom but then decided that the space under it would sort of be wasted and so I ran it to the top of the materials cabinet. It will help keep that from getting stacked on.
It wasn't dry yet so that's why there's no collets in it. I also made it just hover over the material shelf. It's sort of an experiment to see if it will deflect when loaded. My goal in moving these next to the lathe is to separate the tooling for the mill and lathe so they're closer to their respective machines. I may make another rack to hold the chucks but I don't know if that's a wise use of space or cleats. I should make a drawer for them under the lathe but... meh.
So that was today - a day spent making a collet rack. A day well spent.
Gregor
jake28
SF, CA
Another beautiful project.
For other avid followers of this thread looking to do cabinets, one great resource found in [mention]lilscorpion [/mention] thread is A&H Turf for cabinet slides and hinges. Plenty of options and better pricing than I could find on eBay.
(Forum rules won’t let me post a link while still a newb, but, AHTurf.com)
sakurama
Wow! If the new stuff on Instagram is an indication of what’s to come when you do YouTube on purpose, just holy **** Wow.
Thanks.
It's still an iPhone but I'm starting to understand video a bit better and also what I like. I find when I watch Frank Makes I really like the sounds of the machines and the natural sounds. I am finding that I prefer that to music.
So the collet rack video up now was an experiment with pacing and sound. All done in the iPhone with Adobe Rush. While having coffee this morning with the cat in front of the fireplace.
So next step is trying to pull that into Premiere. And real cameras.
Gregor
Joe-R
St. Louis
Gregor,
I’m still enjoying the videos. I liked the rag trick and especially how to measure the distance between two holes precisely.
I have two questions:
In one of the last three episodes you mention a speed chuck for a drill press. I did a couple Google searches, there are a lot of options. Any particular one you might recommend?
When TIG welding the exhaust, how do you hold the pipes in position to tack weld them?
BTW, yours is the first YouTube channel I have subscribed to. I never thought I would say this, but consider me one of your *******!!!
Joe
sakurama
Long time lurker here! I was always hoping one day this thread would venture into video!
Keep it up, I bet you’ll have 100k subscribers within year or two!
I really have no idea how that sort of thing happens but if people like what I do and I can spread some knowledge then we'll call that a win.
Gregor,
Joe
Thanks Joe.
Many of you have suggested that I sell some t-shirst and do the affiliate link thing. I have never attempted to monetize this or anything I do but with the current situation I am going to take a new tack.
So, in full disclosure mode, I signed up for the Amazon Affiliate program. I don't really understand it yet but it seems I get some kind of percentage from things I link to that you or anyone buys from my link. How much that is I have no idea but I don't think it changes the price for you - it just redirects some of Amazon's profit to me. Hopefully Jeff can spare that.
So Joe, you pushed me over the affiliate edge. This is a my first "affiliate link" as it were. This is the chuck I bought a last month - A Vertex keyless:
And I honestly don't know if this is against the rules of GJ so if it is let me know.
I have bought a few chucks on ebay and I've found that it's better to have a new chuck than an one that isn't true. The one I had for my mill before was not perfectly true - it was fine for larger holes but it never got used because of the runout. Scott Kolb turned me onto this one when he was working with me in the shop and I ordered it and sold the old one. It is flawlessly true, has a great action and I'm very happy with it. I find that I am now using the chuck on the mill way more now because I hated the keyed chuck that I had to use before.
After 7 years of this thread you guys probably know I'm not going to shill for something or someone that I don't believe in so hopefully the link is useful to you and beneficial to me.
Let me know how you feel about that going forward.
Gregor
Biff Lungren
I'd have been happy for you to have gotten a piece of what I dropped on the festool track saw and sander and extractor! Great tools that allow me to do things I couldn't before.
And it appears you have stimulated much purchasing of many things by folks here, You're my favorite influencer!
One of my covid projects is looking for a place to set up a drill press that has been stashed for a while. Will evaluate for that chuck if I succeed
jake28
SF, CA
Seriously. I just shelled out for a small motorcycles worth of green tools based on this thread, all due to [mention]sakurama [/mention]
