I need opinions (ideally from people who have experience with this wire size). I am looking at two potential scenarios for a sub panel:
- 45 ft
- Indoors/open ceiling/unfinished basement
- 3x 90 degree turns, 2x45 degree turns, some of these 90 degrees will be “pull boxes” so I wont come close to 360 degree limit
- Either #1 CU CCC x 3 with # 6 GND OR #2 CU CCC X 3 and # 8 GND
Given the above, I would like to find out what conduit size I should be using. Before you point me to NEC Conduit fill tables, I am aware of them, I read them and I know as per NEC i can use 1 1/2” for the #1 cu scenario and 1 1/4” for the #2 scenario.
That being said, I dont know if those sizes are difficult or if I should go with 2” instead. The 2” conduit is huge but I am happy to invest into it if its worth the hassle.
One other question I have is, is there an advantage of using a big conduit in terms of sharing that conduit with something else in the future such as running additional other smaller wires? But is that a big no, in which case this conduit has to be exclusive to the original wires I put in it?
- 45 ft
We didn't have those....
