Tracs
I have a old house with poor duct work. I had to rip the floor out of my bathroom for a cast iron stack replacement. While I had it open I installed a new 6" round supply run to my bedroom. It runs 15' from the plenumn, through the main floor, 10' up the wall to the second floor, and across through the joist space 15' to a 4x10 register.
It is so noisy it is driving me insane. I cannot leave it like this.
It is only the vertical run up to the second floor and across to the register that is expanding/contracting making all the noise.
Everything is still exposed.
What can I do to stop the noise?
Due to sliding the pipe across the floor in 2.5" lengths there are lots of joints. I had to install the angle boot first and then slide the pipe through the floor space, I could only get 2 screws per joint in because I couldn't rotate the pipe enough. I was thinking of taking it out and putting foil tape on each joint?
Is it a symptom of the ductwork being to tight or loose?
