corrugated plastic sun panels anyone use them?
rustycarr
im thinking of installing a corrugated tin roof on my shop and using some of those corrugated panels that are either clear or tinted in a couple of places to let in sunlight, anyone use these? how do they hold up? do they leak or break? thanks.
larry_g
oregon
I installed translucent panels in the old shop along the top 2' of the south sidewall. Very good results and now 25 years old and still going.
lg
no neat sig line
Joe Reed
Cordova TN
I used the polycarbonate ones in a shed at my last house. They were in place for probably 10 years with no problems at all - even survived a pretty bad hail storm.
kbkna
SWEET HOME ALABAMA
Put them on the side wall as I did. Leave the roof metal. You will get great lite and not have the headaches of replacing roofing panels every few years.
Karnage
Brisbane, Australia
I'm Torn between keeping mine and getting rid of them. Admittedly we have a different climate here. While the free lighting is absolutely fantastic, my problem is that I find I get sunburnt and also that the slab of the shed get heated and as such my workshop becomes an oven, saw 50C (122F) most days over summer.
Durability, mine are about 2 years old and have been through 3 hail storms so far, but they aren't old and brittle yet.
R
rustycarr
Poster said plastic corrugated panels. If he is going to use them, then the roof is not the place.
wasnt sure on the materials but this post is eduacating me, i would def go with the best material. thanks for all the info keep it coming.
R
rustycarr
That is also a concern, here in south texas it can get in triple digits for months at time, what about the tinted panels?
Karnage
Brisbane, Australia
The ones I'm using having a 20% tint and that pic was taken about 4pm in the afternoon
Artists interpretation of my workshop during summer
R
rustycarr
wow crazy photo, dont really want heat, thats why i built a shop in the first place!, maybe ill just put a few pieces in my eve area, i do have 4 windows in the closed end , probably dont need the plastic panels anyway... ..
barney rubble
I've got a small 12X22 approx. garage that has 2 of the fiberglass panel that I put in the roof almost 20 years ago. I'm located in so. Indiana and they have turned a little a deteriated to look at them but never a problem with them. I put a line of silicone around them when I put them in and have never had a leak. If they would go bad or start to leak I would replace them with some more just like them I've had no problems as I said and I like the free light they added.
rburke65
Canfield, Ohio
Polycarbonates are technically a plastic. They are used in greenhouses because of their temperature and impact resistance. Very strong.
kbs2244
I doubt your over heating is because of the sky lights.
If you climb up and touch them you will probably find the metal sheets hotter than the plastic.
You need some venting.
logical
Northern fringe of the Motor City Suburbs
"Polycarbonate" is plastic. "Fiberglass" is slang as far as I'm concerned...they are Fiberglass-Reinforced-Plastic(FRP). There is good and bad quality panels in either of these catagories and even plain old unreinforced resin panels...which you guessed it, are also PLASTIC. Could be polyesters, vinylesters, PVCs, etc...or blends. Some thermoset, some thermoplastic.
You need to dig a bit deeper. FRP in general is more stable (shrinks/grows less) in hot or cold temperatures. This may or may not be important.
UV resistence (to brevent them getting brittle after sun exposure) can be done with additives, certain resins or a coating applied to one side of the panel. For polycarbonate panels, it's usually done with a coating so you need to get them right side up when installing. Very sunny areas need to pay extra attention to how the panel resists UV.
Pink insulation is fiberglass...but not pure. Boats are not fiberglass, they would sink...they are fiberglass-reinforced whatever resin. Corvette body panels are fiberglass reinforced plastic (polyesters mostly along with a healthy dose of limestone filler), not "fiberglass bodies". Fiberglass isn't even the highest percentage ingredient. Same with fishing poles, skis, etc., etc.
And don't get me started on "carbon fiber".
Seriously????????? You've never felt the heat standing next to a window exposed to the sun. Never seen a dog or cat curl up near a window on a sunny winter day. The fact that the metal heats up more does not mean it is transmitting more heat. But yeah...regardless, venting would likely help if done correctly.
mikeceli
I used translucent plastic panels and they turned brown and brittle in just a few years. They were NOT the cheapest, nor the most expensive.
Next time, CDX.
shopnut
Florida
I just ripped out all the transluscent fiberglass panels between the roofs of my "monitor" style building and replaced them with real windows. They started out nice, but after 5 years in even a shady site, the panels had a yellow tint to them that really made the light coming through look weird. I also noticed they were kind of brittle when removing them, which surprised me because other fiberglass material I have used wasn't like that. Maybe it was just a low quality product and better ones are out there.
