I am in the process of building a pole barn approximately 300' behind my house. I have 4/0 AL direct burial wire that I will use to go from the house to the barn. I have done some research on how best to do this but I am still confused on a couple things, it seems that there is a ton or different ideas on the proper way to do it. I am sitting here looking at the 2008 NEC and having a hell of a time figuring out what applies to my situation. I want to have a 100 amps to the barn.
At the house I have underground wire coming from the pole at the street to my meter on the side of the house. There is a 200 amp disconnect at the meter because my main panel is inside the house about 30 feet from the meter location. Inside I have a 200 amp panel that has a 200 amp main disconnect.
First question(s) is where is the best place to get power from for the barn?
Option #1: Can I add a second disconnect (100 amp) attached to the meter base outside and run the wire from there to the barn? How would I add a second disconnect, as the main 200 amp disconnect is a part of the meter base and is connected by solid bars inside? Do I need a disconnect for the barn at that location (house) or can I just connect the wires in there and have a disconnect at the barn?
Option #2: Somehow fight the 4/0 wire into the main panel in the house and attach it to a 100 amp breaker. 4/0 probably won't fit in a 100 amp breaker, is there a solution for this?
Second Question(s) are about connecting it to the panel in the barn.
Do I leave the ground and neutral bars bonded or un-bonded. I will drive 2 ground rods at the barn and tie them to the panel. I will have a water line going from the house to the barn but it is plastic pipe so I shouldn't have any other "metallic connections" between the house and barn.
I will probably use a 200 amp panel in the barn just for ease of connecting the wires.
