Help removing concrete anchors
tgmarks
Tupelo, MS
Hi All,
brand new to the forum... I've just removed a portable lift (Danmar M-6) from my garage, and rearranging things, as i'm going to convert this space into my wood working area... The lift was installed using concrete anchors...
Does anyone have any tips on best/easiest way to remove them?
thanks in advance
95vette
Hello, If the hole they are in was drilled thru the bottom of cement, just drive them flush with floor. The only way to know to know is try, cut them off even with with a grinder and cutting wheel, if they can't be driven down. Some can be pulled up with a piece of pipe that is a little larger than bolt and some washers for spacers and nut size of bolt and long wrench for extra power, but they sometimes crack cement and make a bigger mess.
Kaizen
New England
Do you mean the part in the concrete? Why not just fill the holes? Fold anything visible into the hole with a cold punch if you can’t drive them further down
rustyjames
central nj
To my knowledge there's no way to remove wedge type anchors. You can try wacking them from side to side with a big hammer to loosen them up. Worse case is just cut them flush with a cutting disc.
T
tgmarks
Tupelo, MS
thank you for the replies... I will try hammering them down flush, and let folks know how it turns out.
tgm
gmwelder86
Oakdale , ca
Drill them out. Get a rebar eater with carbide teeth. Will go right thru it as long as they are not stainless.
atch
Columbia, Missouri
No answer for your question, BUT: is the Neon Pig still in Tupelo? If it is please go have a burger for me. I've only been there once (just passing through; drove the entire length of the Natchez Trace Parkway) and probably will never be there again. The burger I had there was probably the best I've ever had in my 68 years on this ball of dirt.
Cheers.
rayra
Escaped from Los Angeles
No reason to bother, really, unless you like to futz around. If they are lead lag anchors they'd be easy to drill out. Or as stated above, drive them / crush them down. Then just entomb them with some concrete sealant if you want a flush surface for an epoxy floor finish or something.
T
tgmarks
Tupelo, MS
yep... it's still here as of now... hopefully will survive the trying times
Cheers.
nadogail
Coronado, CA
If your skills will not enable you to gracefully eliminate this problem, you have the option of using brute force.
383
Harrisonburg, VA
Cut them flush with the concrete before you try to drive them down, might get them low enough to patch over.
T
tgmarks
Tupelo, MS
was much easier than expected..... took a mallet... drove them down until flush with concrete, then used a bolt similar diameter and tapped them down until beneath concrete, then filled holes.
one was stubborn and wouldn't budge so had to grind it off even with floor.
thanks everyone!
Kaizen
New England
thanks everyone!
If you ever install anchors like these drill the hole all the way through the slab. If it does not anchor you can just punch it through. Welcome aboard
T
tgmarks
Tupelo, MS
the lift was a danmar m-6 portable lift...
https://dannmar.com/m-6.html
it calls for installing female anchors, and then bolting post in from top, so that it can be removed when want to or not using it. my plan is to move it to another one of my garages once the floor is epoxied, and install it the way it was intended.
the initial install was done like you would a permanent lift.
