Hi folks, couple quick questions I have for this 80 gallon Porter Cable compressor I picked up a while back. I was able to buy this thing for $200, but I had to replace the starter switch (or whatever it was called) in the motor. Still, it's a pretty cheap decent compressor. I haven't had to use it frequently, only every now and then. So usually I just kick it on and run it up to about 130 psi and then manually shut it off. But, I'm about to start some projects and wanna leave it running automatically. However, it turns on at 140 psi and shuts off at 175 psi, which is more than I really need for what I am doing. Which leads to my questions.
First, it takes a little over 5 min to build to 130 PSI. I can't imagine how long 140-170 PSI is gonna take. Also, 5 min seems like a while for it to hit 130, so maybe the pump needs a rebuild. Thoughts?
Second, any good suggestions on a different controller? Preferably an adjustable one that I can set both the turn-on and turn-off points.
Thanks!
Thanks!
