Voi
The threaded fitting that connects the pressure gauge to the switch area on my CAT 5510se broke. See picture below.
I have an old chisel that is the right size to use as a large screwdriver but the threaded connector broke behind the face of the switch assembly and I can't get a Dremel attachment in there to grind slots. It's further back than it looks in the picture. I don't seem to have a file narrow enough to grind slots by hand.
I've removed the plastic switch housing in case I need to apply some heat but the rubber diaphragm that activates the pressure relief valve is right behind there so I'd like to avoid heat if possible
I'm probably going to need to venture out of self isolation today anyways so if somebody can recommend the right kind of extractor I can go pick one up.
