Joelk
Has anyone done this?
If so, what were the results?
How long did the tool last?
It's illegal, punishable with up 5 years in jail and a $2000 fine, don't do it.
I don't see a huge problem with doing it (keeping in mind that the motor was most likely designed for lower voltage and might burn out prematurely) other than having bungee cords on your tools. I'd just get a new cordless set or rebuild the 14.4 volt batteries.
Just found your thread, much appreciated thank you as I am considering doing similar, in my case with a 15.6V Metabo Drill using AEG 18V Li-ion Batteries.Just an FYI.
It has been over 3 years since I converted the tool and it is still going strong.
It is stronger/faster than at 14.4V and no signs of impending failure.
If I ever find Dewalt 18V - 20V Max adapters cheap, I will probably permanently mount one on it and go to newer 20V Batteries as my supply of 18V batteries is now getting low.
I am wondering if everything you are talking about is are NiCd batteries?
If you are referring to me, I started the thread before the 20V Max batteries were the norm and I used the 18V NiCads, for quite a while. I now use a "permanently attached" 20V-18V adaptor and use the 20V Max batteries.
There's no way that any 18V drill operating at 14.4V would have as much power, I notice that easily when my 18V drill batteries drop voltage that much. If it just used faster gearing to achieve similar RPM then it wouldn't have the torque it does. I expect it would burn out at 18V if under a high load.
^ It seems like you are heavy on words and short on understanding. There is very little "pump more current", it is purely a function of the battery voltage.
As I already stated, I think my 14.4V would burn up if put under heavy load....
Thank you so much for the followups! Wish everybody did that.I am wondering if everything you are talking about is are NiCd batteries?
