Tackled a couple of small projects so I wouldn't feel so trapped.
Had a corded drill and one of my 4.5-inch angle grinders in a drawer in the garage tool chest, along with a few abrasive disks and wire wheels. With my new Milwaukee M12 drills and impacts, I haven't used the drill in a long time. I also don't like to use the angle grinders in the garage where abrasive dust lands on the cars. I took the drill and grinder out of the drawer but left most of the disks behind. I also left one of my Dremel tools in the drawer because I use it to sharpen tungstens for the TIG welder. Drawer looks pretty empty. I may have to buy a new tool or two.
I found a spot for the drill in the workshop tool chest in the same drawer as my 1/2-inch hammer drill. I wanted to try to fit the angle grinder in the table saw upper cabinet drawer but there's two blow mold cases for Dremel tools in the drawer. The long case is for a recently deceased Dremel that went into the garbage (switch is no longer available and I broke the one in the tool trying to get it to work). The case also has a rarely used engraving tool and a bunch of stones, wire wheels and sanding disks in it.
With the long case out of the way, the drawer has space of all of my angle grinders and room for a bunch of my abrasive disks. The grinder at the top of the photo is my first -- impulse buy because it was on sale but I had no idea 4-inch grinders had so little support. Live and learn.
Decided to just add all the Dremel accessories from the long case to the Dremel/Burr drawer with a 'someday re-organization (the other Dremel case in that table saw cabinet drawer has a tool and accessories as well).
Decided it was time to restore some of the organization to the workshop, with a temporary shelf. Used 2x6 lumber scrap for the shelf and some packing lumber from something I bought a long time ago. Made shelf brackets out of the packing lumber.
The brackets worked great with a couple of construction screws attaching them to studs and into the 2x6.
Re-used the brass-plated steel kickplate from the front door remodel as an attachment for the parts cabinets but most of the weight is on the two-by shelf. One more shelf for the other side of the window and I should be able to get the remaining parts cabinets hung, freeing up the table they've been bowing for the past year.
