Trying to locate a #8 Bolt Extractor
meburdick
I have a Symmons Temptrol shower faucet that needs rebuilding. I have all of the parts AND the special four-way tool from Symmons to install and remove the cold and hot water seats.
I -ALSO- have the extremely common issue of the cold water seat basically being stuck and the tool stripping out the brass when trying to take it out. My research has basically shown me that about the only hope I have of getting this thing out at this point is by using a bolt extractor and that I need a #8 to do it. The opening of the cold water seat is in the area of 3/4", so that size seems right.
Can anyone tell me where I can actually buy one of these things? Box home improvement stores, auto parts stores, plumbing supply stores, TOOL stores all don't have them. They are basically nowhere to be found.
Alternatively, if someone knows of a way to get that cold water seat out without the use of an EZ Out, please share! :)
Thanks!
DFB
Southern VT/Western Mass
Sounds like you're looking for a 3/4" internal pipe extractor? That be a #8
Either a cam action that expands when you turn it or one with a tapered spiral shank?
And you have a square tool now thats not working?
meburdick
meburdick
https://www.homedepot.com/p/Armour-Line-3-4-in-Internal-Pipe-Wrench-RP77363/306716191
I've seen items like this, but no one ever talks about using them. The inside of this particular piece is not constant (after the initial opening, it increases in diameter before reducing again), so I have no idea if it would actually be able to grab on with how it's designed since this is intended for something different.
https://www.plumbingsupply.com/extractors.html
Maybe? It would be great if I could find someone, anyone, that had used this exact item to do this particular task that could validate that the next to the last one is the right size. Otherwise, it's almost $40 to "try" it.
https://www.amazon.com/RIDGID-35685-Extractor-8-inch-1-inch/dp/B001SXNDYS
I haven't seen these, but same concerns as the first item plus they seem to be for fixed sizes (no taper) and this isn't a standard inside diameter of pipe.
https://www.homedepot.com/p/Husky-Pipe-******-Extractor-Set-6-Piece-410-391-0111/309997715
See comment from previous post.
DFB
Here's the part that needs to be extracted:
https://www.homedepot.com/p/Symmons-Temptrol-Hot-and-Cold-Seats-TA-4/300300621
It's the larger of the two shown in the picture. The section that's threaded (on bottom in the pic) is the outer portion as it threads into the valve body.
I'd try using one of these internal pipe wrenches before resorting the common bolt extractor like the HF link but IMO that style is probaly better than the long taper ones
https://www.homedepot.com/p/Husky-Internal-Pipe-Wrench-Set-16PL0140/304217608
Buckgnarly
VT
This looks like it "could" be the right thing, but what the photo shows is a product that's threaded the wrong direction. This would not work for extraction as pictured.
How about this...My Ridgid kit has these but longer....
https://www.amazon.com/dp/B001SXNDYS/?tag=atomicindus08-20
Actually upon further review I do have those in my big Ridgid kit.....if you want 3/4 you need part number 84 for 3/4 pipe.
https://www.amazon.com/dp/B001P307N6/?tag=atomicindus08-20
