thewaydown
I'm restoring a floor model Rockwell drill press model 1124 (pretty sure its almost identical to the 15-081, but im not sure, cant find a manual for it). Before I get started, I'd like to get an idea of what I'll need to order so I'll have it ready to go.
Below is a picture of the chuck. Its a Jacobs No. 34 and reads "cap 0-1/2" next to it. I'm not sure how to remove this particular chuck. I've done some research and havent found a definitive answer. Does this particular chuck come with the taper attached? Would I just disregard the threaded portion just above the chuck? From what I've read, it seems like the threaded portion is for attachments, or for a different style of chuck that would thread on instead of wedge into the quill with a taper. Would wedges work for this style? It looks like the gap between the top of the chuck and the threaded portion is about 5/16", I dont know if that gap is too big for wedges to work.
I'm planning on replacing the quill bearings as well. Does anyone know what particular bearings I'll need and how many? Will I be able to do the bearing job without special tools? I don't have any sort of press, other than a small arbor press. I was also reading I might need a pulley puller to get the top pulley off. Is that the only way to do it without breaking the pulley?
I'm going to purchase a link belt also, which is pretty straight forward, but is there anything else I'll likely need to replace on a drill press in this condition?
I appreciate any help.
Thanks,
Zayne
Thanks,
Zayne
