Workbench - free standing or wall mount?
mmsheb
Wisconsin
Looking for the good and bad points of having a free standing or wall mounted workbench in my 24' wide x 28' deep garage.
Thanks,
Mike
danielbuck
By free-standing, do you mean like in the middle of the garage so you can walk around it?
Shiftless
East Bay SFO
It greatly depends on what work you might be doing in your garage.
I have a smaller garage, 20x20 in which 2 cars are parked most of the time. Obviously, I back one of them out for significant project work.
For that reason, one of my benches is on wheels (locking castors) It’s handy to pull out to the middle if I’m putting something together that needs access from all sides. That bench is 2x4 feet.
The bench I use most often is permanent. Lag screwed into the wall framing in back and supported in front on 2 4x4 posts. I have drawers built in underneath for storage of tools and supplies. That bench is 30 inches by 7 feet.
mmsheb
Wisconsin
Your permanent is what I used in my last garage. It worked OK, but since I am starting new thought I would explore my options.
Shiftless
East Bay SFO
For example... If you have a mounted vise and use it to do heavy work of any kind, you’ll want a bench that doesn’t move around. If you want the best of both worlds, build a bench on wheels with some wood or metal extensions on the back that you can screw into the wall to make it a fixed bench. When you need to move it out away from the wall, just grab your cordless impact driver and zip out 2 big screws and you’ve got a mobile bench.
My smaller moveable one usually sits against a wall. It looks a lot like this one I saw online.
I use the shelf on mine to store power tools in their original plastic and metal briefcase sized cases.
ddawg16
S. California
If you have the room......both.
Wall mounted is great use of space....storage under it...cabinets above. But sometimes it's hard to work on large items.
I have welding table with my big vice attached to it. It's not huge....2'x2'...but heavy....over 250 lbs....heavy enough I can beat on a driveshaft bushing it doesn't go anywhere.
And then I have my table saw....the outfeed (back side) is a 3x5 heavy slab of butcher block (thanks for a neighbor who was throwing it away). I do a majority of my work there. The whole mess is on wheels if I want to move it.
mmsheb
Wisconsin
Hey, that might work for me. I'll see what other ideas I get. Thanks.
mmsheb
Wisconsin
Probably not both. Maybe the combination of fixed/attached, but removable by removing a couple of lag bolts. Thanks
nadogail
Coronado, CA
My work bench is on wheels, actually a Harbor Freight tool base that has a foot pedal that raises the fixed legs so it can be rolled around and than lowered so the legs are again on the floor. The advantage is that I can roll it out and walk around it like an island or push it back into the corner where it normally resides.
All of my shop equipment is in wheels or casters so that I can have good access to it and still keep a car in the garage. The bandsaw is fed by a power cable suspended from the ceiling joists, with an appropriate strain relief. The arc welder and table saw time share a 220 Volt receptacle with an 8 gauge extension cord feeding them.
A heavy duty, bolted to the floor, workbench would not be the most convenient thing to have in my small shop.
mmsheb
Wisconsin
Thanks. I don't have the equipment that you do, but I'm beginning to see the advantage of a movable workbench.
Keep those ideas coming!
zippyslug31
Central Oregon
If you plan on banging on things very much, I'd steer clear of a wall-mounted. Anytime I've done that, and had to get violent with a project, the sound reverberates throughout the structure. I say free-standing, but heavy and solid... I'd even forego the casters unless you really think you'll be moving it much. Of my dozen or so workbenches, 2 are on casters and I very rarely move them around.
Your mileage (and space) may vary.
mmsheb
Wisconsin
Some good points for me to consider. I'm thinking free-standing, heavy, and solid positioned near the wall. Could be moved out into a larger space if needed with some muscle. Thanks.
matt_i
SE Michigan
Build it with a toe-kick recess that's designed for a pallet jack. Around 3-1/2" tall x 28-30" wide. Then the solid-leg bench will roll easily to another solid position.
mmsheb
Wisconsin
You mean I need a pallet jack then?
tarmy
Nor Cal
Fixed bench...
Rolling bench...
The first two are built into wall...the last one is one that I roll into the shop to make up cabinets and items that I want access to.
LeonardY
Southern California
I have both. A bench to do "clean work" on and a heavy duty roll around. In order to roll it I have to turn the wheels in the direction I want to go.
It's worked well.
mmsheb
Wisconsin
Fixed bench...
Rolling bench...
Those are very nice. What I want buy way more than I need. Thanks for showing me.
48windsor
Olympia ,Wa.
Interesting thread .
I read with interest , some good points for both types of workbenches.
I have always had a workbench against a wall and definitely mounted to wall!
As mentioned for serious work. I myself am leaning towards a freestanding bench so that I can get around all sides of it especially since I have a vice at one corner which kills flat workspace for fabricating. Mounted to floor.
I am also going to have a 20x 20 but will only have a pickup on one side and workshop on other half.
mmsheb
Wisconsin
It brings out that we all need not one of everything, but multiples of everything - just in case! Appreciate all the responses.
Joemctag
Outside raleigh nc
You probably can’t go wrong with free-standing. Also, a great way to get an assembly/fabrication/project surface is a pair of trestles (sawhorses) with boards and OSB or something. Make your own however high and long you want them. Lots of great plans and ideas for them out there. Some fold flat and you can store them. If you do buy them, well, I’ve not seen any yet that don’t wobble too much for me.
didit
S.W. Ontario
I built a 5' x 2' steel bench that is not lagged to the wall but has no wheels and is very heavy and stable. It was an overbuilt project done after getting a new stick welder and using all the structural steel and plate steel I could get for free. That was 40 years ago and it will still be around a hundred years from now. I put some drawers and lower shelves in it. Excellent bench that is the nucleus of the garage.
Because my garage is not large enough for another bench, I have a few outside the door that get used regularly. One has a roof over it and is built from 4 x 4 lumber and the other is a large cast iron framed picnic table that came from the Ford Motor Company (very heavy). No wheels on these either.
What I do have with wheels that I use for a bench when needed is a single scaffold unit with locking wheels. It can actually be folded up when not in use but I just use it for extra shelving most of the time.
Other than that, I only have a few rolling platforms used for moving heavy things around and a few engine stands.
Never had the need for anything else but I would love to have the steel plate build platform a friend has with the grid lines and levelers built in but don't have the space.
My nephew built a really nice steel plate top that is hinged and bolted to his wall. When not in use, it is folded down allowing for another car to be parked, taking up no floor space at all. When raised and the legs locked down it is 6' by almost 3' deep and very solid.
Just a few ideas to mull over. Good luck!
mmsheb
Wisconsin
Thanks. So maybe I will do the combination of one workbench lag screwed to the wall, and the pair of sawhorses with work surface (freestanding) to use as needed.
mmsheb
Wisconsin
I'm not a welder, so will probably go the route of a heavy duty wood bench lag screwed to the wall and an occasional use free standing workbench. Your work area must be rather large. Thanks.
