Paint for trailer deck?
BMWBOB
Washington State
If enclosed, I'd just use a good primer and paint it with exterior latex. If you have a ramp, salt some sand on the paint before it dries.
I used leftovers to create a beautiful shade of "Walla Walla Silt Loam Tan". In fact, painted the whole inside of my shop with it!
Ilikeike
Northern Ca.
I used oil based from Home Depot on my open deck car hauler diamond plate, primed first.
Then some anti slip from Napa where the wheels track.
This Is the only picture I have of it on my phone. It’s held up well 2yrs so far.
tarmy
Nor Cal
I have used a good quality stair paint. Has sand or grit in it...holds up well and makes for a non slippery surface that is durable. Usually lasts about 5-6 years.
mikegt4
sw ohio
used motor oil.
Used anti freeze works well too. I apply it with an old garden sprayer. Keep pets away until it dries (or cover with a tarp). Even though it sits outside my 20 year old equipment trailer still has it's original deck. Also solves the problem of getting rid of used anti freeze.
AMCguy
Sunshine Coast, BC Canada
Rustoleum (or Tremclad if you live in Canada).
Thin the first coat so it really penetrates the wood then apply the second coat as usual.
It holds up well. I just did my steel truck deck for the first time since building it twelve years ago.
Glenn
Sureshot
Bridge Creek, OK
If it's exposed you could also look at fastening from the bottom or gluing it down to prevent the screw openings for water to get in.
matt_i
SE Michigan
How about pressure treated plywood or marine plywood to start with?
I think you'd have to use peel + stick to cover the metal frame where it touched.
