4xdog
I refinished one of the headlights on my 2008 RX350 using the headlight restoration kit from Griot's Garage in September 2018. I was really pleased with the results. The 3200 grit Micro Mesh sanding pad does a fine job of prepping the weathered polycarbonate lenses, and the sunlight-cured UV coating went on perfectly and cured hard in a sunny afternoon.
I have a small spot beginning to weather off the center of the lens after 18 months. Griot's talks about two years life, so I'm probably in the window. Perhaps my coating wet film thickness was too thin in that area.
Buying another Griot's kit is probably my first choice, but it's an expensive item for the small amount of UV coating that's included. There's enough coating to do two lenses with little extra and the spray can doesn't like to be part used and stored (it seems to evaporate from the sealed can and doesn't spray well several months later).
I've tried SEM's UV clearcoat, and normal daylight doesn't seem to be enough to kick off the cure, whereas a sunny day is more than enough for Griot's. I've tried some other clearcoats and they're not as clear or as good at leveling as the Griot's stuff. It really is a good coating...
Any recommendations from the gang would be appreciated.
Here's a before-after comparison on my RX. The 1.5+ year old coating looks almost like when applied but for a spot smaller than a dime that seems to have weathered off.
