rerod
Hi folks.
I know AG metal manufactures say to screw through the low flat section, and they say it's because screwing through the high rib, with much less chance of a LEAK, will deform the rib since its hollow.. But Ive also read old timers swear they will always screw through the rib, because they were taught this way 50 years ago installing corrugated with nails..
I see pictures of new corrugated metal roofs screwed through the high part of the rib/wave.. Is this because the rounded shape of corrugated metal has more compressive strength?
Because of this high dry screw, low wet screw issue, corrugated roofing (if screwing through the high rib is correct) has the advantage IMO. I'm not sure me using the word issue is in correct context here, because leaks can be devastating and here we go drilling a bunch of holes through a perfectly water tight roof panel.
Or is it the fact the old timers had good luck up high because a 10' panel will expand/contract 1/4" in most climates, elongating screw holes and unscrewing screws when screwed down in the low's? Because placing a screw on the high rib would place the screw sticking out of the wood 1" and might allow the screw to flex enough to not egg the metal out?
Anyway, I like snaplocks hidden fasteners, but don't like how the manufacture double the price pound per pound going from AG metal to snaplock. I'm trying to figure a way to reduce my chances of a exposed fastener leak if I choose to go that cheaper route.
I noticed the nail holes in my old corrugated barn roof don't leak long after the washer dried up and fell off. Even with a nail missing.. Why? I'm guessing because the nail hole is on top of a rib drastically reducing the amount of water introduced to it since the water wants to flow down hill..
Thanks
Thanks
They must not know anything..
