SGKent
Pulling new coax for if we go to Comcast / Xfinity. Need guidance on grounding for lightning. We are in a suburb of Sacramento and don't see much but sometimes it happens around here.
Power, telephone/DSL, and gas come in on the N side of the house. Water on the W side, and Comcast on S side. 30 years ago when I had Comcast it came in on the S side, wrapped around to the E side and came in thru a hole in the wall/siding. They put a lightning arrestor on the outside and tied it to an aluminum patio cover. The patio cover is mounted to wood and concrete. No real grounding. I added a grounding rod for the spa that I used to have and tied the patio cover to that as well.
When the house was re-sided (T1-11) I moved the coax to inside the attic and added a lightning arrestor on the outside before the coax entered the attic, whether from Comcast/Xifinity, or an off the air antenna that I had at one time. That arrestor is grounded via a 10 ga grounding wire to a 8' rod in the ground on the S side of the house. It does not tie into the house wiring. The service entrance for electric is 50' way on the other side of the house. There are copper pipes in the wall near there but they run up and thru the attic. There is no house ground on that side of the house other than electrical plugs in the walls.
I am trying to figure how to properly ground the coax at the point of entry. Can I continue to use the 8' grounding bar with the 10 ga wire? Or do I need to tie into the house ground which I wonder how I would do that considering that service entrance is 70' away with the distance and drop. Also the main water entrance is a type of plastic pipe so I can't run a wire around the house 30' to that point to get a good ground. What do you electricians do in a situation like this?
