70runner
7K two post lift, about 7yrs old. For last couple years have noticed an issue with unequal lifting and lowering. Left side has 1-2sec delay when powered. Left side also lowers at faster rate. I can compensate by using the safety locks during lift and lower, but need to get this fixed as it seems to be getting worse.
The lift worked fine for 4-5yrs. Pressure lines are identical lengths. I've done the bleeding procedure several times but has no effect on issue. Candidates would seem to be the flow divider or left side cylinder. Suggestions?
