New lift, need help
Dutch106
North Carolina
Hey all,
I’ve recently purchased an atlas pv10px 10k lbs capacity lift. I’m going through the hardware kit that came with it and I’ve noticed that one of the supplied anchors appears to have corrosion on it. I’m not sure if I should be worried or not. I’m questioning replacing just the one anchor with one from Home Depot, or replacing all since the two different anchors have two different torque values. I’m also considering epoxy anchors. I want to make sure I install the anchors properly since ya know, I’ll be standing under a vehicle on this thing.
Thanks guys
ovilla
Plainfield, IL
I’d break out an angle grinder and hit with with a wire wheel real quick. Then go ahead and use it.
Wamsutta
Amarillo, Texas
If you're OCD like me - and go ahead with installing those anchors, you'll be laying awake at night thinking about the anchors continuing to corrode beneath the surface of the floor. You'll be imagining the lift falling over because the anchors have disintegrated into a fine metallic dust. It's not worth losing sleep over. Replace the anchors now.
SeisMec
Beryl, Utah
Can't you get non-corroded OEM replacements from the lift manufacturer or supplier?
D
Dutch106
North Carolina
It’s odd because that one anchor is the worst one. All the others look fine except for another one that has a very small amount of corrosion on it. That one I’m not too concerned about. Ive found replacement anchors from homedepot and Lowe‘s but their toque values are different than what the lift company recommends
Jking24
You could wire wheel it then spray it with some cold galvanize if you were really concerned
Wamsutta
Amarillo, Texas
In that case I'd get them straight from the lift company; that way they can't say anything if something goes wrong.
IndyGarage
Indy
That looks like a standard stud anchor to me. Personally I'd use it as is, but if you really don't like it go to the hardware store and pick up another one.
