EvellSnoats
I want to put a utility sink in my garage that is really a part of an old carriage house. The 4" waste pipe is about 30" off of the garage floor, so I need a pump to get the water up to the connection to the drain. The utility sink is actually sitting right by the drain line in a corner, so the pump does not have to be particularly powerful.
I reviewed the instructions for a couple of inexpensive non-vented pumps that I thought about buying, but they both say that your lift should be at least 6' to preserve the check valve life. Does anyone know of a "low lift" pump I could use to tie in so I don't have to make the lift so high?
Anyone got any other ideas I should explore? The sink won't get a ton of use, mostly just hand-washing and filling mop buckets.
