Jacobs makes sets of wedges to remove the chucks. They are pairs so the force is directed square to the spindle. You place them between the chuck and the collar.
I was just reading about them, as a matter of fact. I think I'm going to e-mail them so I can be sure to get the right size.
For now, here is another update: I took the whole thing apart, the only attached pieces are the column and the base. It might as well be welded on. I don't want to risk cracking or chipping the base by banging around all over it. I stripped away the remaining paint on the head and scrubbed it with some greased lightning and water. I took the collar locking handles and miscellaneous hardware to the wire wheel.
I have the table and head support collar soaking in greased lightning and water. The spindle pulley cover, motor bracket, and feed lever are soaking in evaporust. I cleaned up the pulleys and got the motor detached from the bracket. The bearings are in excellent shape.
The motor is pretty dirty, and while I was getting the pulley off a brass nut for a terminal fell out. Yikes. The wires are exposed right at the connection to the motor and the insulation along the power cable is brittle and cracked/chipped. When I plugged it in after I first brought it home, it didn't do anything but hum. I plugged it in again now that it is off of the DP and it immediately tripped the breaker and sparked at the outlet.
I also uncovered the original paint color and will be trying to match it to the best of my abilities. It it a blueish-gray. I actually really like it, surprisingly.
Anyone got any tips for cleaning the column? I was thinking wireless drill and wire wheel.
Sent from my SM-G973U using
The Garage Journal mobile app
