alan camby
Today I was running some Romex to lengthen a 3-way switch run. All the cable is behind drywall and I assumed that there was at least one or two staples somewhere behind the studs. Running all new cable would have been a major pain. So I installed a 4-11/16 junction box to the old cable and came out with the new yellow nm Romex cable. This new style...well been out for probably 20+ years, has a really thin yellow cable jacket.
So I clamped the cable with the common romex j-box clamps. Turned power on after installing the new switch further down the wall. Pop goes the breaker. Now I just snugged these clamps but they cut right through the cable and power shorted to ground. Pulled to a new spot in cable. Took some of the old thick style Romex cable jacket off the old romex and used it as a added protection layer. Careful just snugged down the clamps and all is good now.
So do they make a thin protection kind of wrap for Romex to install where it is clamped? I can't find anything with Google. These clamps come from India or some place like that and are full of sharp edges. I got mine at lowes, and yes they were for the nm style wire as I know there is a slightly different style for mc style metal clad cable. Just seem like these clamps are hard on the cables. Oh and sometimes I need to run more than one cable through a clamp so really want to avoid the cord grip style with the rubber insert that smashes around a cable( the style that is usually used with SO cable)
Thanks for any advice.
Attached is the style I used but they were for the 1/2" knockouts.
Sent from my SM-G965U using The Garage Journal mobile app
