Dont use wood it splinters/Its also flammable
Wood are excellent for cribbing when used correctly. It’s used by many rescue crews all over, including myself as a FF attached to a heavy rescue.
I can't imagine Firefighter trucks are ever supported by wood during any type of professional repair procedure
Rescuing people in an emergency is very different to trying to save a few bucks by not using the correct tools
Wood blocking has far less long term durability than metal jack stands. And moving a jack stand and raising its saddle seems remarkably faster than moving and stacking separate two-by, four-by or six-by wood blocks. But faster and more durable do not necessarily mean safer.
Almost all commercial jack stands are designed for use on non-deformable, approximately flat, and approximately level surfaces - like the concrete floor of a shop, dry and well packed gravel or perhaps an asphalt driveway. In the later case, one had better add the privisio that it's not a 110F/43C afternoon.
A few jack stands have support pads under their feet like this one.
A few have no support pads what-so-ever. But more typically they have recessed support pads welded inside each leg about 1/2" above the foot. ( Look closely at the rear most leg of the left hand jack stand in the picture below.) Should the thin edge metal of a foot crush into the supporting surface, the recessed pad is there to provide a last ditch increase in weight distribution.
In most situations, properly utilized wood blocking is just as safe as jack stands. The converse is not true.
I carry a couple of metal ramps for my trailer, and use them under the jack/stand if I need to
Metso calls out wooden cribbing to support mobile crushers while they are in operation. I've seen a drilling rig with 18k of 5 inch drill pipe (534000 lbs) cribbed up with wood. If it came out tomorrow we couldn't use wooden cribbing at my plant it would take somebody a month just to fabricate metal cribbing for things we use wood for regularly. Point being wood is perfectly acceptable for cribbing and is regularly used for things a lot heavier than a fire truck.
When you get away from the automotive shop, Worksafe BC recommends either using wood cribbing or the appropriate jack stands for supporting equipment and heavy vehicles. . A bulletin was sent out a few years back because somebody was crushed when repairing a truck after the jack stands collapsed.
Small jack stands that fit under heavy stuff are sometimes not the right capacity. Good quality ones are not readily available and the easy sourced cheap stuff is well made in you know where.
Typical way of changing a tire on a tractor using a bottle jack and a 6x6 block. Stands or blocking would be used for support if left for a extended period. We use a railroad jack sometimes when clearance allows but its not that extra safe when lowering it . Kind of like a farm jack.
Back in the day (40 yrs ago) we changed the engine out of a wrecked import. We were going to use jack stands, but a pro mechanic said wood blocking was safer, And gave us an approximately 20” high stack of 2x6 or 2x8 boards, all nailed into one mass, 30” long, one for each side. Was far safer than the 3 ton jack stands he said, you’ll never knock the car off them.
I use jack stands and a proper hydraulic jack because its the correct way to do it. If you want to crawl around under a truck supported by wood or a ****** bottle jack knock yourselves out!!!!
Tell your wives and kids good luck with the life insurance
You don’t know jack about what you are talking about.
Quality hardwood blocking (never pine) is an excellent, versatile cribbing material. It also has an advantage of providing much more friction than steel on steel. Not only do I use cribbing to support heavy machines every day. I have also welded, used torches, and thermal lances in very close proximity to cribbing and it holds up just fine. It’s not saving a couple bucks, it’s the way it’s done. We have 25 ton jack stands as well but they take a lot of footprint and are difficult to deal with and a lot of time will not fit. A cribbing tower is easy to build under a machine, can fit odd shapes better, and is very solid.
I have also been operating a machine that was thrown off steel stands due to slipping while in the lifting and blocking phase. The wheel loader pitched off and the oscillating rear axle let me tip over to the side and get a good view of the table where all my tools were laid out on. Thank god she didn’t roll all the way over. Took a while to negotiate for the release of the seat cushion by my *******. That was a moment I wish I had used cribbing instead of stands.
Now I will say it would be unlikely for me to use cribbing to support a car simply because the jackstands are a lot easier to deal with device for that application, outside of building cribbing towers for say a long term pull engine/trans type thing.
I know all about jacking and supporting vehicles after 35 years of auto mechanic work, but thanks for telling me a load of irrelevant stuff before admitting you use jack stands, its entertaining but it doesn't change the fact that wood is flammable and has no place underneath vehicles when humans are relying on it not to kill them
In fact it's f*cking mental that home gamers who think its fine to rely on a bottle jack and have no clue about safety are being encouraged to go underneath vehicles supported by random bits of old wood by people on the internet who are so f*cking full of themselves and how knowledgeable they are, that they might end up killing somebody
I'm saying to you home gamers/DIYers use proper rated metal jack stands on a solid level base under the appropriate section of the vehicle, dont use old bits of wood or bricks or any other stupid sh*t like rubber tyres
because nobody really wants you to die!!!!
Cool story bro
Cars are less flammable in the USA, probably because we are not cursed by Lucas, Prince of Darkness.
... are being encouraged to go underneath vehicles supported by random bits of old wood by people on the internet who are so f*cking full of themselves and how knowledgeable they are, that they might end up killing somebody
1. We are talking about lifting and supporting cars and light trucks not "heavy equipment", most of which tend to run on highly flammable gasoline (in your country at least)
2. All wood is old, it's made from trees, those big green things in the park![]()
3. If a guy doesn't know not to use a bottle jack as a jack stand, why is it a good idea telling him to use wood??
4. I'm from the place where the "Industrial revolution" started and I'm well aware of wood being used to support things (some of my older relatives were pit chockers), It's not how to support a vehicle that you intend to work under though!!![/QUOTE}
Does that qualify you as an expert? Wood cribbing is fine under all sorts of massively heavy equipment, but it's just a death trap when supporting a car or light truck?
Think about what your saying guys, jack stands are the correct tool for the job!!!
I have thought about it. Jack stands are a (not the) correct tool for the job. They are also more convenient, not much more expensive, generally less of an obstruction, and probably more idiot resistant (but by no means idiot proof) than wood cribbing. None of which make wood cribbing an incorrect tool, nor jack stands the only tool.
Pour gasoline on asphalt, ignite the gasoline with a torch or welding spatter and the tar in the asphalt will burn too. So, never, ever work on an asphalt surface. Cotton and polyester catch fire easily and burn very quickly. So, only wear leather when you're working on your vehicle. Anything else is just never, ever safe. Give the fire hazard a break! I'm pretty sure anyone with a IQ at or above that of your average five year old knows that wood burns.
So 'old' is a relative term. What's your point?
Because wood can be an appropriate support. If you mean more detailed advice should have been given about the quality of wood to use, what size/shape pieces to use and how to stack it; well, yes, that's probably true.
Meh, I'm unconvinced your trying to help anyone and think your more interested in whatever point your attempting to prove (to yourself), tell inexperienced people whatever you want, I'll be sticking with the metal jack stands advise because its better/safer and faster
and if somebody does get crushed to death there is a paper trail for the coroner's office
Why are you worried about how the Vehicle is supported if you aren’t working under the vehicle? If you are just replacing a tire, leave it up till the task is completed. IMO putting yourself in harms way to lower the vehicle down without a tire and then back up simply to reinstall the tire seems silly to me. If it’s going to be a extended period of time till the tire can be replaced, invest in some jack stands.
All this over how to support a vehicle during a simple tire change?
Actually at the Los Angeles County Fire Department (with 72 bay doors), cribbing is often used to work on not just engines, but ladders, tenders, bulldozers, and aerials. (We don’t use the term “Firefighter trucks”)
Furthermore, you have NO place telling us professionals (especially me) who did this for a living using wood cribbing. You remain steadfastly stubborn despite the facts & testimonials presented to you.
Folks like you pisses me off.
I only have a pair but three is all you really need.
Here is what I ended up doing.
