GeddyT
I have a question about my overhead door that's been bugging me for a long time. When I ordered the door, I ordered a high lift track to limit how much light the door would block when opened.
This is what they gave me:
I know nothing about garage doors, so I figured it's what I wanted and installed it. I wound the springs per instructions, aligned and leveled everything with lasers, and I've still never gotten it to both open and close without difficulty. If I over-wind the springs by a couple of turns, the door opens with only a little effort but then binds when the bottom of the door is just below the top of the opening and takes quite a bit of effort to break loose from this point to close. If I leave the springs wound per instructions, it takes quite a bit of effort to open and a LOT of effort to open it past that sticking point of just below fully open.
It's a Clopay steel door, fully insulated, glass up top, and quite heavy. Every other picture I've seen online shows a smooth radius for a high lift track, but mine has two pretty sharp angles that the door seems to catch on at certain points in its travel. Doing some research, Clopay calls this a "25 degree high lift" track, which is supposed to be for extra clearance for exterior windows and handles and whatnot, although my door has nothing protruding on the front.
I guess my questions are:
1.) Was I given the wrong track for what I'm trying to do?
2.) Am I just asking too much in expecting it to smoothly open and close with no binding points?
3.) Is it possible I'm just a crappy installer and a it's just a matter of minor tweaks to align things perfectly? I mean, it's not perfect, but I didn't worry about doing the install myself because I didn't think garage door tracks had tolerances in the thousandths...
I've had a jackshaft opener sitting in the box waiting to be installed for over six months now, but I'm afraid of burning the motor up based off of how much effort it takes to both open and close the door past those sticking points as it sits. Any advice would be greatly appreciated. My back's been hurting lately, and it would be nice to open that door with a button instead of a deadlift...
