bikesandcars
- Joined
- Nov 4, 2016
- Messages
- 127
My shop is 64' long and I want to put a 100 amp sub panel on the opposite side of my 200 amp main panel / service entrance.
The most direct route is to go up into the attic and run it across and down. I also view this as safer than having it in the walls.
It's for home shop use. I'm planning on using #3/3/3/5 copper SER. Maybe a little "over-kill" but sound OK?
For the attic I saw that NEC requires protection in a 6' radius around my attic entrance.
Since I want to run other cables to that same side is there some kind of residential cable tray system I should use? I'm running perpendicular to the trusses. Can I make a cable tray out of 2x4's nailed to the trusses and just lay my cable in it?
Thanks!
Thanks!
