Hi all,
Probably a beginner question - but I can't find anything from a google search.
I am working with PVC conduit for my outbuilding's service entrance. I know that there are threaded male adapters available for PVC conduit. But I am trying to connect the panel on the inside straight through to two different boxes on the outside (LB conduit body and an AC disconnect). The distance between the panel and the outside wall is, obviously, very short. If I use two male terminal adapters then the length of the conduit won't allow me to mount the conduit body and disconnect flush to the outside wall.
I know that with EMT you can use short threaded *******, and this seems like it would solve the problem I am having. But are threaded ******* available in PVC?
I found these, but although they are sch 80 and grey, I don't think they are UL listed for conduit (but maybe I'm wrong?):
https://www.supplyhouse.com/Spears-884-025-1-x-2-1-2-PVC-Sch-80-Threaded-******#product-overview
Sorry if I'm being dense, but what is the solution here? Should I just use EMT conduit for the service entrance instead so that I can use the threaded *******?
Thanks for reading
Thanks for reading
