Old Man Roger
Palm Coast Florida
THIS WAS my 26 gallon fire extinguisher.
It now runs the whistle and the air horns... Just. Because. It. Can.
That whistle use 26 gallons of 110 psi air in just over 2 seconds.
The horns are just horns.
The trombone (who's going to pass up a $30 trombone?) isn't hooked up yet. I need to make the diaphragm and housing and I'm not too motivated.
The trombone will eventually go under the hood of the rv.
I think I can make it 'blat'(the noise a Jake brake makes but forward, over blown, not backwards) which will be a nice horn for an rv.
Deep note should penetrate just about anything.
I would hate to be your neighbor..lol
sweetk30
finger lakes area upstate ,ny
cleaned out corner area . setup new compressor and blast cabinet . just need power and few feet of black iron pipe and a flex hose and were ready for action . :beer:
bobj49f2
SE Wisconsin
Finally got some air lines run. My air compressor is up in the mezzanine and up until now I had a hose running from the compressor out through the sliding door and dangling down. I ran both the feed line and the the drain line done to the shop floor. I have pipe openings at each end so I can later run pipes around my shop. For now this will do.
My phone decided it wanted to take crappy quality images today.
View media item 104182
View media item 104181
Kevkx125
DOUGLASSVILLE, PA
Put the stain on one side of my trailer decking. Made a pile of bike parts I don't need
Dan in Pasadena
Pasadena, CA
Painted my stem walls flat black in preparation for my True Lock Ribbed flooring coming later this week. Crawling around on my knees all day is tough.
There will be baseboard put on top of the stem walls.
Ron_J
Central PA
I welded up some in-floor receivers in anticipation of my new garage that they are supposed to be putting up within the next couple weeks.
I did this in my existing garage several years ago and love them.
Dutch01
Kempton Park, South Africa
Modified an old A-frame to fit the front nudge bar of my Nissan Hardbody so I could tow it home from my SIL's house. Also made and fitted temporary wheels to my radial arm saw so I can move it in and out of my garage so the Nissan can go through to the backyard.
Spanner
Spain
Just getting this buggy stripped down for selling f8e3d0718af01875db0d55b5b3b395da.jpg
Tool Junkie!!!
PhantomEB
Medicine Hat, AB, Canuckistan
Nothing in mine other than restocking the beer fridge.
But did get 3 4.3l Chevy’S and a Ford 250ci in-line six ripped right down to bare blocks as well frost plugs and cam bearings pulled out in two 6 hour shifts at my buddies machine shop these past two days. Guys ***** about labor work, but 20$ an hour plus learning experience is well worth it for me.
Kevkx125
DOUGLASSVILLE, PA
Changed the location of zip-tie holder's to my nut & bolt bin rack. Got my final pile of bike parts together. I am going to donate them to the local bike kitchen in READING a little shop that lets people of READING to come there and work on their bikes. they offer help and advice if needed. And I check on the drying stain on trailer deck boards.
Charging the battery on the project van because I'm an idiot and left the lights on when I came home from buying a new battery for the T-Bird... (Which I changed out Sunday...)
Irony!
sweetk30
skat blast 960 / I.R. 2420n5 t30 hooked up and did my first blast tonight old dirty / blasted clean pic of 2 brass comp fitting nuts .
LS6 Tommy
Northern NJ
Not much. I was off for our Anniversary, so I kept my time in the garage down as much as possible. I did fix a brand new solar garden light that came with am intermittent switch (second order in a row) and reorganized some of my toolbox drawers when I had a few moments waiting for Mrs. LS6.
Tommy
LS6 Tommy
Northern NJ
Thanks! I almost forgot, we went for a drive this afternoon and I found a 3 D cell Maglite at the side of the road. It's a little beat up, must have been run over a few times. It didn't work, but I found the bulb had a bad filament. I got it home and and swapped the bulb out of my old 4 D cell model and it works fine. I just ordered two liteXpress 360 lumen LED upgrade bulbs. When they come in I'll post a review.
Tommy
BigSteve63
SW Missouri
Tommy
Same here! 31 years today - spent the day just hanging out together and then went for a real "sit down" meal in restaurant.
LS6 Tommy
Northern NJ
Congrats! Beat us by 5 years! Normally we'd take off work on the Friday before or after our anniversary, go to the Warwick Valley Winery, then hit Mt. Fuji on the way home for dinner. Both are currently not an option with the virus safety restrictions.
Tommy
ZRX61
Solar Blight Valley, SoCal
Cleaned the windows inside & out.
Noticed the plastic cover on the drill press looked a bit iffy so it got the Chemical Guys VPR treatment. Also did the plastic pieces inside the trunk of the Honda, there's nothing left to do inside the car.
Then decided to also do the inside of the storage area on the ZRX & the compartment in the tail*.
I seem awfully motivated for some reason this past week. Not sure what's got into me.
* & the underside of the rear fender, the black plastic drip pan & a flashlight
BigSteve63
SW Missouri
Tommy
Congrats to you and your bride as well! Had some friends comment that after this long with me, the better half must either be incredibly patient or has learned how to settle with her situation...
Hope you had a great day!
Steve
Jagmandave
Overland Park, Ks.
Got in a whole load of parts for the classic Mini engine I'm building.....
ZRX61
and now my orange & black Horrible Fright 7in variable speed grinder/polisher. Might do the Dewalts tomorrow.
So first the strangely blonde hair & now all this motivation... only thing I can think of regarding the motivation is I've actually been able to walk pain free for the past week since I got that gel injection in my OEM knee. Getting the 2nd shot tomorrow.
LS6 Tommy
Northern NJ
Steve
If you add in the 10 years we dated before we got married, I figure we've been together longer than most "good" marriages last. :lol_hitti
Tommy
earl84
Colona, CO
Went from a mess to organized. This took a while, but finished yesterday, then used new workbench to change motorcycle tire.
kaymccampbell
Upstate New York
Finished up all the addons for the compressor. Just needs copper lines. Which needs a JIC flaring tool that's on order.
Kevkx125
DOUGLASSVILLE, PA
assembled some front to back braces for the car port and installed them. stained the other side of the trailer decking.
Put the battery charger away and re-coiled a 50 ft extension (Project van was parked at the curb)
Made a list of all the nasty solvents, chemicals, and oils I keep. :shocking:
What for? Going green?
Not really, Just inventory; some I have more than a lifetime supply, some I'm about out... Need a list of what NOT to bring home... (A sealed gallon of 70 year old Rifle Bore Cleaner? Seemed reasonable at the time... and I have other smaller containers - this was my "bulk" section)
White gas/camp fuel on the other hand I use a lot of. (I keep a "dispenser" with 3 gallons in it)
niget2002
Josephine, TX
Trying my hand at making a cutting board and fixed my 9mm using parts the mfg sent me.
If you ever want to get really good at making joints... Try doing a cutting board. 929776a2cbf354b638da7a1ad75dd193.jpg
Sent from my LM-G820 using Tapatalk
BigSteve63
SW Missouri
Built a Taryl-inspired string trimmer/bicycle clamp from scrap conduit, scrap DOM tube, and HF vice grip clamp. Started simple enough, but now has "extra" adjustability in mind. No in progress shots, but at some point, my welding skills seem to have vanished. Now working on becoming a "grinder" Tomorrow, will build base for clamping to bench, then paint.
Pressure washed the Kubota and the burner cover/grates from the pellet grill. Grill stuff pretty caked after 3-4 smokes of pork loin and brisket. May start wrapping burner cover plate with aluminum foil - has anyone done this? Any downside? Pellet grill is Pit Boss 820
Planted magnolia tree for my Mom; wife selected a couple of flowering crabapple trees to plant here at our place. Trying to find the "perfect" locations - walking around yard with beer in hand...
Plan for tomorrow is to complete the vise stand and rotate the tires on the wife's Accord. Vacation days are a lot of fun!
Steve
Flat Thunder Channel
Squat night in the makeshift garage gymnasium. Lots of grunting with a little lifting. Haha. Also snapped a few pictures of the Atlas lathe nameplate. I owned it for almost 7 years and couldn't couldn't remember the model number. Drr mush brain.
bobj49f2
SE Wisconsin
Not what I did today but will be doing this weekend.
Has grounding short of a wire in my '49 F-2 Ford pickup this afternoon. Burned the bundle of wire from the radiator to the firewall. I'll be replacing the wires this weekend.
C_F
Utah...SNOW BLOWS!
Aww hell, I hate it when that happens! :mad: What's the relay in the first photo with nothing plugged into it? A leftover from some past accessory long since removed?
