Gehl 2600 Skid-Steer Rebuild
redm18
Center Point IA
Sorry for the word wall
So I noticed that Skidsteer content seems to be popular on here lately so maybe I would add my new little project. I have about ¾ of an acre in a small town in a house we bought last year. I have a 33x26 3 car attached garage and a very rough 16 by 24 foot pole building with a gravel/dirt floor. My wife and I park the daily drivers in the garage with the third stall pretty much taken up with my tools. The lot needs a fair amount of work done in order to get the yard in the shape that I would like. The main tasks will be filling in several large areas in the yard that are low spots, sloping the ground around the foundation away from the house, spreading gravel around probably 35 feet of driveway to get from the pavement to the street, adding a 26 by 12 foot gravel pad next to the garage to park a pickup and popup camper and spreading a good layer of fresh gravel on the floor of the pole shed. I think all of this is probably beyond the stuff at least I can do with a shovel and a wheel barrel.
Enter my new project I found on market place. It's a Gehl 2600 and it came with a big empty hole where the engine would be. The guy I bought it from said he bought it in a lot with some other stuff he wanted. He said the engine had a hole in the block when he bought it so he pulled it, scavenged some parts off it, and scrapped the rest. Other than an engine it seems pretty complete and I’m hoping if I get an engine it will work. If not I guess I get to tear into everything else. I believe it came originally with a 2 cyl Onan with about 22.5HP. There are repower kits on the internet with a Briggs Vanguard, a Honda GX690, and a Kohler for between 2k and 3k. I’m thinking I will go a little cheaper with a Harbor Freight Predator 670 at 22hp. Pictures to follow later.
AngryBeaver
Lake Milton Ohio
look for a used kubota 2 cylinder or 3 cylinder. Those old gasser skid steers really **** when that gasser is screaming away. you only need a 12=15hp diesel to accomplish the same thing and you can usually find the D500's, D682, D722 etc for very cheap. the 25+ hp ones are the expensive ones
R
redm18
Center Point IA
A few pictures
R
redm18
Center Point IA
I thought about that but this thing is not very big at all and it probably won't be used a ton. I don't know if a diesel will fit in it and if it will how tight a fit it would be. I also kind of want to keep it as simple as possible.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I had one just like that. I didn't care for it too much and sold it. What I was doing around our property, it just didn't have any *** to it. You can't spin it with the joystick like you can with a dual levered skidsteer, and the gas engine just sucked. Luckily I knew a few guys that had Bobcats or Case that I could borrow.
Currently I have a 27hp diesel Cub CUT that does more than I could with the GEHL ever could.
Like AngryBeaver said above.....find a diesel engine to throw in the GEHL and you'll be better off. You might have to remake/weld some new mounts though.
R
redm18
Center Point IA
OK I will ponder the power plant for a bit. I probably have a few other things to take care of first anyway. Maybe start with the hydraulic system. So I have two hoses that are not currently connected to any thing that should connect the the pump pictured. Is there anything I can do with no power before I get it back hooked up? Can /should I change the fluid? Do i somehow purge air? Should I change the spin on filters? Is there any way I can lift the bucket so that I can get access to the chain covers and inspect the drive system?
AngryBeaver
Lake Milton Ohio
I'm not familiar with that particular machine, but the pump bolts to the engine. the pump will run the hydraulics and the drive motors. that setup is simple easier to adapt to any engine. it is a smaller pump, that is why it won't have the *** to do a lot of lifting. you won't have the problems I did lining up up the engine to the drive pumps since you don't have drive pumps. the down side is slow machine hydraulics while driving, since the pump has to feed both the drive motors and the hydraulics. the plus side is you can literally adapt any engine to it super easily.
I'm not sure on that machine, but in order to lift the boom without the hydraulic pump running, you'd more than likely have to remove the hose to the boom cylinders to allow air in. you'd need a chain hoist or forklift to be able to do that easily.
The pump will prime itself once running, as long as there is oil in the sump. Changing the fluid isn't a bad idea, but I'd do it once you have an engine in place and it running.
whatever engine you find, you will need to determine clockwise or counterclockwise and find out what the original engine was so the pump doesn't spin backwards.
R
redm18
Center Point IA
Where would you get a small diesel engine like this?
AngryBeaver
Lake Milton Ohio
kubota 2 cylinders are pretty easily found for cheap out of 80-90's garden tractors, small equipment like water pumps, golf course sand trap machines, etc. they only make 12-14hp and aren't useful for larger equipment. even a 16hp 3 cylinder is small. they are also smaller than any comparable gasser lengthwise. Yanmar also has a ton of small 2 and and 3 cylinder engines. Even single cylinder for that matter.
R
redm18
Center Point IA
So how worn are these types of engines likey to be? How would I evaluate?
