lafester
I would just leave it there and repack it unless it is trashed now.
Nice job. It's coming along nicelyI have a question about the quill on these little guys.
Not much holding them together, a slide on collar on the top and a screw on collar on the bottom.
How much play do you leave for the spindle to spin freely? Seems like the too much to me but otherwise the fiber washers will just get torn up with friction.
Here is a tease pic of the press so far.
Looking Good!!!!!
Unicorn Item It Is Indeed, I just missed One last Year, early 2019For me, quite a bit. It has been a Unicorn Item for me for a while. The head is the same, check the base to make sure nobody just put a bench model on a longer pile. For me, I wouldnt be as worried about the head, as I could simply swap my known good head onto it.
Sent from my Phone 2 using The Garage Journal mobile app
It's all together now. Just fine tuning at this point.
Well I paid 30 and sold for 90.Here is a question. What would you pay for a Mohawk floor model 103.0304? I see 103.0303/5 fairly often, missing parts for $50-$75. Never seen the floor model.
Just wondering.
Just wondering.
Yeah. Intent is a huge factor.Well I paid 30 and sold for 90.
Shoot I got about $500 into my floor model. Spindle pulley was worn, needed the depth stop, put on a middle pulley, and added the table lift.
Was the $500 invested worth it, hell yes.
Is there a way to separate the pulley from the spindle?
What is the model number of your machine?
There is a link in the first post of this thread titled "Spindle Pulley Assembly" that explains how to remove the assembly.
If your question is not answered there, please reply again.
I don't have the actual model number but I know when i looked it up that it was an "80"
I did read that section and quite a few others before posting. I appreciate all the info you have put out on these.
I haven't removed mine yet but it appears that the spindle and pulley are cast as one part.. is that correct?
Not sure what you are referring to with regards to matching...
The spindle pulley has built in splines in it, which makes the spindle rotate. The motor pulley is a smooth bore with a keyway, as it fits onto a motor. If you mean that they should both be just a pulley and not a shaft...not sure why that would matter. Otherwise, they aren't matching on the inside, so why care about an "extension" on one?
Thanks
I really want the pulley on the spindle to match the pulley on the motor but the idea of using my band saw and lathe on a piece that can't be replaced scares me.
I don't have a pulley for the motor. I can't find a matching pulley that would have the same steps and diameters as the spindle pulley so each speed change would require a belt change. I may buy identical pulleys and just machine the spindle to accept it.
Not sure I understand
1. it seems no matter what pulley set you have/use - there is only one speed per set of pulley steps so a belt change is always required to change speeds?
2. The spindle splines are integral to the drive system - are you suggesting you would machine the female splines into a smooth bore pulley?
I may be completely missing the thought process - if so I apologize
Rick
If you have to make a pulley, why wouldn't you make one that matches the one that already exists? Your statement makes no sense.
Dave
Rick
This drill press popped up 20 min away & for the right price - I had to get it! It’s not in great shape, but it’s got a Vari-Slo attachment!
Hi
I find this thread as I don't know a lot about drill press in general and just accidentally get a 100 series (103.24810) as my first drill press due its sturdy looking! But it turned out not a such good purchase as it wobble a bit on the drill bit
Long story short. Went through manyof posts in this helpful thread and realized that the spindle is not installed properly. It misses the threaded thrust collar, and all the rubber rings and washer etc that is mentioned in the "spindle pre load" section.
What option do I have for the missing collar? wait for a donar to show up? Ebay seems have the upper collar available. I am not sure if I can used that as lower collar, as I understand that the threaded portion is not that important.
Thanks
Welcome! Hopefully, we can help you get your machine running again.
It's very unusual that the thrust collar and other parts are missing. That makes me think the spindle was bent, the previous owner attempted to repair it and gave up.
When you can, please post some photos of the spindle, chuck, etc.
