Between 705 & 1200 SQ/FT Kevkx125's garage in progress
K
Kevkx125
DOUGLASSVILLE, PA
andyaus-I basically have it for the in case I need it situation like I need to take the mower to the shop or I need to tow a street bike or who knows?
K
Kevkx125
DOUGLASSVILLE, PA
I'm with you Kev
Every busy guy needs a couple of trailers. You never know when you might need one (I have 3 different ones)
Thanks for stopping in DON. Yea DON never know when I might need to haul some thing that won't go well in the bed of the truck and just works out easier with the trailer.
K
Kevkx125
DOUGLASSVILLE, PA
Hung some l brackets up to store some lumber on. not perfect or permanent but will do.
K
Kevkx125
DOUGLASSVILLE, PA
Finished wiring the trailer, took it for a tow down the street to mo buddy's house for a bit. Now look a empty bay!!
K
Kevkx125
DOUGLASSVILLE, PA
Toyed with my mt125 today I put fresh gas in it and checked for spark. It had spark so i gave it a few kicks and it started but couldn't keep it running ,so I pulled the carb and sprayed some 2+2 in the jets and passages put it back together and no luck so I pulled the carb again and checked the needle and seat. It won't hold pressure so I am going to have to order parts. I Fixed the batt. leads and tried charging the batt. but won't take so will have to get a new one.
K
Kevkx125
DOUGLASSVILLE, PA
Bit of a bummer day in the garage. A thunder storm came through and brought a limb down and bent frame work on the carport. Hopefully only a minor set back already have a idea for the next roof.
jon72vega
Niles Michigan
Kevkx125,
That *****.
Hope you can get it repaired the way you want it.
K
Kevkx125
DOUGLASSVILLE, PA
My friend and his son came by today and helped me put my carport back together, putting a temporary roof on it using a blue tarp for now. I am on the look out for some steel roofing sheets to match the garage for it.
K
Kevkx125
DOUGLASSVILLE, PA
Thanks for stopping in JIM. It sounds like it is going to get its first test on thur. they say a 80% chance of rain. Fingers crossed no problems.
K
Kevkx125
DOUGLASSVILLE, PA
Power washed the front today
K
Kevkx125
DOUGLASSVILLE, PA
Today my friend came over and helped me widen the shed opening so I can put my mower in there.
K
Kevkx125
DOUGLASSVILLE, PA
went from this to this more room!!!
K
Kevkx125
DOUGLASSVILLE, PA
I put a coat of stain on the shed doors today and a new tarp on the carport
K
Kevkx125
DOUGLASSVILLE, PA
Isn't it about time to make that carport into a leanto?
That was my original thought kay, but I think I should check with my township to see if I can add a permanent structure to the side of the building. I figured with the carport. if it wasn't allowed it would be easy to remove. My garage width just fits within my set backs.
K
Kevkx125
DOUGLASSVILLE, PA
Picked up a harbor freight m/c lift.
K
Kevkx125
DOUGLASSVILLE, PA
Worked on my honda mt 125 , got it running and took it for a ride.
