Indestro #1238 1-3/16" socket needed
mred49
Md
Well I finally found and bought an Indestro #1242 1-5/16" socket! So now the only one I still need to find is the Indestro #1238 1-3/16" socket. If you have one or know of anyone who has one please let me know. Ed
xela456
I can understand the want to complete a set.
Unrelated though I've had a 1-3/16 proto impact socket for 10 years and I've never encountered a bolt that size! I have used the socket though on 30mm bolt heads. Now I've got the proper metric sockets though!
Good luck with your search!
Incidentally this was about the 7th line down in my ebay search
https://www.ebay.com/itm/New-Duro-I...305151?hash=item5da520227f:g:tqcAAOSwjzleBqAW
Does that fit the bill?
lardy1
The only reason I even have 1 3/16" socket is that I saw it used at a flea market for a couple bucks. The chrome was beginning to peel a little but I bought it anyway, knowing it would likely never come off the storage rail.
The socket I'm referring to is a 1/2" drive SK Wayne 12 point.
mred49
Md
I guess I'll never know!
Ooops. Unfortunately I screwed up and didn't mention that the socket I need is the 12 point 1-3/16 Indestro or Duro-Indestro one. I have a 6 point one. Thanks. Ed
Downwindtracker 2
BC
I was going to say suggest 30mm, a size as common as dirt, but I see you are completing a set, good luck.
mred49
Md
Thanks! I have a feeling it will take a lot of luck to find what I'm looking for. I might be wrong, but I think Indestro only made the 1/2" drive 12 point 1-3/16" sockets for a very short period of time. Ed
xela456
Not really. Did another eBay search, #2 on the list had a 1/2 drive 1-3/16 12 point in a lot with 2 other sockets. Do you have some issue with eBay?
mred49
Md
xela456 wrote: "Not really. Did another eBay search, #2 on the list had a 1/2 drive 1-3/16 12 point in a lot with 2 other sockets. Do you have some issue with eBay?"
Maybe I'm not searching correctly. What did you use to do the search? Thanks!!! Ed
