Keeping paint can lip clean
bobj49f2
SE Wisconsin
I've always punched a couple of holes in the lip of the can to allow the paint to drain back into the can. Worked OK but still had cans sealed themselves tight.
This looks like a lot better, and cheap, way of keeping the lip clean.
<iframe width="514" height="367" src="https://www.youtube.com/embed/p216HGaM5cA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
lilredex
Toronto
If you only need a little bit, I use those "dippers" that come with laundry detergent. Or, if you need a bit more you can tape a popsicle stick to those plastic cups that bring you apple sauce.
rlitman
Long Island
I can't say I've used it for paint, but I use thrift store kitchen utensils around the shop all the time. Cake spatulas for plastering for example. A 50 cent ladle might make sense here...
WunTon
My house in Purcellville VA
Home depot has rubber pour spots that snap onto the inner lip. They're $1 and work great
Your friend has shared a link to a Home Depot product they think you would be interested in seeing:
FoamPRO 1 gal. Paint Can Pour Spout
https://www.homedepot.com/p/FoamPRO-1-gal-Paint-Can-Pour-Spout-61/100254956
This is what I use as well. Works great and gives a nice sturdy surface to brush the brush against to remove excess paint. I can see the tape method working really well for smaller can and probably stain which is usually the smaller cans.
bonneyman
Desert SW
Great idea, but I think I'll pass. I won't be able to tell the color of the paint in the can if it isn't slobbered all over the outside! :lol_hitti
txvwnut
Bedford, Texas
I've always put a strip in the groove for the lid with the sticky side towards the inside of the can. But the idea in the video looks much more effective.
foodie
That is genius agree,...thanks for that since I am painting my basement,...love those little tips and tricks!
slackdaddy1
Southern MD
My problem (With cans of Alkyd Enamel) is the paint drys out after opening the can.
After 1st use, cleaning the lip, and putting the lid on, a couple months latter the paint is drying out. now put the cans in ziplock bags. appears to work.
DJL1967
Northern Ontario
I have a small can of Por 15 paint that I use for touching up rust spots on my truck. I only need small amounts at a time so what I do is take a small screw and screw it into the lid of the can without removing the lid. I can pour a small amount out of the can into a cup then put the screw back in. The paint will dry around the screw and seal the can from any air. I have had the same can for over a year and have not removed the lid.
LS6 Tommy
Northern NJ
I've been using one of these for years:
IDK if they still make them.
I've been told storing your paint cans upside down keeps the air out. Never had the guts to try it.
Tommy
like2wheel
On an as needed basis
I think most people are missing the best point of the ops method is that there is nothing you have to CLEAN after pouring the paint.
Sure, I have all those plastic gimmicks; they work well enough for latex paint, but they really don't have a place with automotive paints. Not to mention that most only fit gallon cans.
HotrodHR
North Alabama
Clicked on the link and took me to the spout with craziest description, "helps with any job, particularly tight or moulding work; extendable pole with threaded grip handle makes painting a breeze." Man that sounds like a helluva deal for 98 cents!
FoamPRO
Helps with any paint job, particularly tight or moulding work
Compatible with most paint buckets
Extendable pole with threaded grip handle makes painting a breeze
LS6 Tommy
Northern NJ
All good points.
Tommy
Ikrop
London
I use this unit from Home depot too and can definitely recommend it to others. Works great.
