Dry Lube for Spinning Tool Handles
JatoTheRipper
PA
I have researched dry lube for this application, but I wanted to double check with you guys before marking the purchase. I am looking for a dry lube to free up the rotating handles on the ends of these hex drivers. They are supposed to spin freely, but there is no bearing and the anodizing must be a tad too thick so they don't all spin freely. My concern is that I don't want a dry lube that will be stick or too thick which would lock up the caps all together.
What would you guys recommend to free up these tool handles?
darkzero
SoCal
I've had good results with these. CRC has a graphite spray too. There might be better brands available but these were readily available locally. Can't say which one works better though as I use them for different things & have never tried them on the same application.
REI (if you have one locally) or most bicycle shops should have this. Should be more like the PTFE spray above that is a translucent white. The dry moly & dry graphite drys black/dark gray if that matters to you.
scubadoober
I have had good results with microlon gun juice, but it might be overkill for this application.
darkzero
SoCal
Actually I would just try some oil or even grease like super lube first. Dry lubes are mainly used when you don't want the lube to attract dust or whatever. Not really necessary for a screwdriver like this.
J
JatoTheRipper
PA
Lots of great feedback so far. Thank you!
I don’t want the handles to be oily and slippery though. The handles don’t have too much grip to begin with and these wrenches shouldn’t ever really get oil or grease on them so I don’t want to introduce any.
SeisMec
Beryl, Utah
Lack of grip is the exact opposite of my expectation.
Graphite spray is easily wiped off smooth areas. Maybe use masking tape to keep it out of the knurling - no matter what you decide to use.
darkzero
SoCal
Don't need a lot of oil. Just a drop or 2 with a needle oiler would do. Spraying the dry lube in there will be much more messier. Will need to clean off excess for sure.
I was just recommending trying oil first cause you probably have it already. Buying a can of dry lube is kind of expensive unless you have other uses for it.
Hands001
Keep them clean and dry; they should last many years. I’m on the fence, but would do myself, use green slim on the O-ring to keep it protected.
M6erfan
'Merica!
^^Does it have an o-ring? I'd try NyoGel that I have kicking around, used to lubricate o-rings and threads for Al <-> Al connections.
frankieg
London, UK
I would use dry graphite. You can use it for loads of other jobs too, like lubricating door locks, etc. Doesn't attract dust and dirt like oil.
noid
Amsoil HD metal protector; it dries to a wax like finish.
rlitman
Long Island
J
JatoTheRipper
PA
This site is awesome! You guys are giving me options I've never heard of. Thank you for the continued responses.
rlitman
Long Island
Thanks, rlitman for the pocket knife advice.
Any time. Yeah, wet lube on a knife just sticks to all sorts of lint and turns into a gummy mess.
Wax lubricants work around dirt by shedding micro-crystalline wax particles that clump as they get dirty. The wax crystals themselves are not as slippery as teflon or other dry lubes (though many will include other dry ingredients), but when it comes to shedding dirt like a dog, nothing compares.
About graphite (since I see it in a bunch of posts above). Graphite (like any good dry lube) also doesn't attract dirt. However, in many situations graphite is abrasive, and when used around metal, graphite can lead to unexpected corrosion. I don't use graphite dust for anything any more.
