Organizing parts bins, need input
mendozer
I make a miter station and also obtained a few parts bins containers for a steal off the list of Craig. I have 120 small bins, 24 big (they all have dividers, so I could double that number easily for variety but lose capacity).
I made a list of the most common things I'd use, that way I wouldn't have to run to the store for little things here and there
Thoughts on the sizes, types, anything I missed that you would put?
Mattlt
MN
That's quite a list!
Maybe further break it down by drive type? Phillips, Square, Torx, etc.
Suggest buying bolts/nuts/washers at a place that sells by the pound so you can grab more of the sizes you will use instead of whatever package size is offered at some stores.
MushCreek
Upstate South Carolina
I find that I run out of short (1") carriage bolts and machine bolts first. You can always cut down longer ones, though, as long as they are fully threaded. I have nuts and washers running from #6 up to 3/4". I buy most of that kind of stuff by the pound at TSC.
matt_i
SE Michigan
I might have missed something but you are calling for 18 bins to store 3 sizes of nut (??) I understand there are nylocks, torque prevailing, square nuts, etc but I can't think of 6 useful types...
mendozer
in that example I listed the three most common nut sizes I've used, of two types. That was a typo and should be 6 bins not 18. I must have carried that cell down from the bolts, which had three lengths, making that count 18 bins. I was going to do just regular, and maybe locknuts.
Good point on the by the pound places, I was planning on the small baggies at home depot that are a buck or so each with anywhere between 5-10 pieces of the item.
One thing is the really long bolts or lag screws won't fit in here, so I may make simple shelves to store these flip top "parts bin" containers I got at costco. Probably can hold up to 6" bolts in there, or maybe make my own plywood trough. Don't want to go overboard but I hate whenever I'm mid project and go "****, have to drive 20 minutes to buy two washers now". Really puts a damper on my mood haha.
I will likely have several bins empty for the random stuff that I'll need once in a blue moon like a pack of star washers, or a spare nylon spacer, stuff like that.
rigid1
Depending on your location you may want to try a Fastenal store. In most cases they will have bag quantities like 50or 100 of your most common used sizes of washers, nuts, screws etc. Much less than small packages of 5 or 10 at a time
mendozer
to give you an idea of the bins
engineer2
Chicago burbs
I am sorting 40 years worth of screws, nuts and bolts plus what I inherited from Dad. It basically *****. You fill a bin with #8 sheet metal screws, and then you find another container of them. Or you find variations of screws and wonder where to put them. Is it a #8 or a #10? Might be a #9 or some Chinese size. Whatever you do has to have the flexibility of creating more bins or dividers. On a similar GJ thread someone suggested tossing all the oddball and extra and just buying what you need when you need it. They might be right.
mendozer
Yes I have that stuff in a separate area, but I imagine I'll have bins here left over for terminal adapters, splices, etc
