Hey, I think I need something like that. That's awesome. Can you suggest to me I can I get that?
I've been using small Anex handles for my coin slot & faucet bits. Been fine for me except one day I used the faucet driver on something really tight & couldn't apply enough torque with the little handles. No problem as I just used a different handle to get the job done but I then want bigger dedicated handles for when I needed them.
Got these Vessel screwdrivers. Thought looked a little funny at first but I really like them now.
Koken 137 ratcheting ring wrench For 1/4" and 3/8" sockets
Engineer's new magnet design fits on screwdriver shafts between 4 and 6.35mm. I'll probably add a couple to an Amazon Japan order after they are released on June 25th.
<iframe width="560" height="315" src="https://www.youtube.com/embed/QhGDlFd6Q38" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Some real nice additions, guys
I'm slowly working on my wish list for my next order. Can I get some feedback from those who own the Ko-ken spinner handles (e.g. 2769NWF). They are wobble/fix. Am I correct to assume that the shaft is the same quality as their extensions? What is the handle material?
may I ask for some comment about Deen tools? They seem to have quite rich offer. Are they big among other Japanese tool makers?
I've got the 1/4 drive with wobble-fix. Not having it in front of me, I can't say for certain, but the shaft is likely to be the same as their extensions.
The handle material is 2-component. The grey is hard, and the black is soft rubber. The amount of grip offered by this grip design is superb. I only use it for a particular use so it's never seen oils/solvents, and so I don't know how durable they are when exposed to them.
It is standard size, and 10mm deep. You can use it as a stubby ratcheting driver in a pinch.For anyone with the Vessel ball grip ratcheting screwdrivers: what is the interface like between the ratchet and shaft? Is it a standard .250 hex, or something proprietary?
@kblee27, I presume the tool was useful so you weren't dropping hardware into the abyss? (or you were able to feed it back into place easily) I use the locking extensions anytime it's problematic to have a socket fall off. The other thing is your extensions might be to blame. I took a 14mm surface drive Koken socket and tried it on various Snap On and Craftsman extensions and ratchets and it held tight. Only on the Koken wobble extensions does it seem like it might slip off if I was pulling it out of a tight spot quickly and it caught on something.
^ Have you tried locking extensions? Sorry, I don't know of any made in Japan locking extensions to post a pic of.
is there currently a way to order from i-tools now that rakuten global has shut down?
out of the box, the kai cuts fabric so beautifully and smoothly. like i said before, even friction across the cutting stroke.
the shozaburo required adjustment to the joint. closer to the joint, there was some play which resulted in grabbing instead of cutting. tightening the joint fixed this, but unfortunately by the time it was tight enough to cleanly cut everywhere, the friction became inconsistent across the stroke. towards the end of the stroke, it tightens up some, and then there is a bit of a looser spot, and then it tightens again as the tip closes. if you're not careful, i feel that this could result in accidentally cutting past the intended point. i tried playing with the joint tightness more, and i can't really adjust it out. not a huge deal, but i just share this info as a comparison between these two high end (and high priced!) shears.
especially considering the kai is less than half the price (4.4k vs 10.9k jpy), i have to say i am much more impressed with the kai.
i'll use the kai on normal fabric and abuse the shozaburo hard blade on tougher fabrics, rubber, leather, etc.
Received a small delivery of a KoKen this morning.
I’ve been managing with a few mismatched XZN inserts for too long, so got a proper set of 3/8 drive XZN bits.
These universal sockets were purchased on behalf of a friend. They’re one particular item that KoKen do very well.
I’m always very happy with KoKen purchases. The tools are decent quality and very consistent. They always do what they are supposed to, and I never feel ripped off at the cost!
Universal Whitworths? Don’t think even Snap On offer those..
Yes, you’re right! Good spot!
There are relatively few applications that those are essential for, and I think they’re all aerospace related, but I find quite a few occasions when they are a big time saver, usually working on machines.
And you’re right about Snap On, they don’t offer them. I don’t think they ever have. Most of the old ones I see are Britool.
I think KoKen probably offer a wider range of sockets and accessories than any other maker right now.
