Hvlp gun straight up?
Kaizen
New England
Going to be blasting and painting under my truck. Going to spray rustoleum from a harbor freight hvlp gun. It has a screw in container on top of gun. How do I spray the floor which would be straight up? Do I point it at 45 degree so it doesn’t run dry?
Marctrees
TX/LA border - Toledo Bend
Seems to me to buy a cheap primer gun w a cup under the gun.
Still won't be able to shoot straiight up, but w turning the pickup tube toward the back adding a short rubber ****** to it, and turning vent hole tube up front, you shopuld be able to shoot closer to plumb.
Probably fill cup less than half full.
Marc
K
Kaizen
New England
Marc
Thanks. Might be the easiest thing as i have a lot under there to spray.
Bill Bowman
Metro Chicago
To get around wll the nooks and such, you almost need a pressure pot, which will allow you to point the sprayhead in any orientation without either bumping something or loss of paint. Keep in mind, that as you spray upwards, a good amount of paint will snowfall into your face. Laying on your back is the least favorable position. Lift, better. Rotisserie, most excellent choice. Good luck.
K
Kaizen
New England
Yea it will be on a lift with csi plastic protection all around. Just finished blasting it outside on my back and that sucked.
karoc
Hemphill Tx
You may have better luck with HF airless paint sprayer. Yea HF HVLP is 19.00 and the airless is 200.00 but you be able to successfully have it painted.
Awag
SE NE
I've been out of the body shop for 8 years. I think it was 3m that had a system that used a plastic cup with a liner that you put the paint into. You then screwed it onto you paint gun. If you held your gun upside down and pulled the trigger it would pull all the air out and you could paint holding the paint gun in any direction.
UglySign
That would be 3M PPS and could get in the way
Bill has it right
Busted Knucles
I would do a majority of it with a brush to minimize the misery and health risks. Then spray into the areas you cannot get with a brush.
