Here’s a couple of different pics of the Prentiss jewelers vise.
Sent from my iPad using The Garage Journal mobile app
Josh, thanks again for the Tip on the vise, I wouldn’t have it if it wasn’t for your info. It’s definitely going to a good home. The only downside is that I’ll never get to see how much it resells forSmitty, gotta say the vise is absolutely jaw dropping, just outstanding without question. Thrilled that it ended up in the hands of a caretaker who throughly appreciates it and it’s rarity. Couldn’t ask for a better foster home when you consider all the playmates it has now!! Nice that worked out for ya. I always like to pass along those desirable pieces that for some reason I am unable to get to or keep an eye on. That one just came at a time when I already had several irons in the fire that I was obligated to see through and I didn’t like the thought of it disappearing and not knowing if it went to a good home or not. You saved me some sleepless nights I am sure ������ Josh
No new vises here lately. But I did pick up this cast iron stand from a WardWell Manufacturing band saw blade sharpener. I had been on the hunt for something like this for a while. Now I just need to get a piece of plate cut for the top and its ready for some paint! Its got a cool 1 inch hole through it near the top. Ill have to get some 1 inch rod to make some hammer hangers or something.
Edit. I was looking on vintage machinery at an old catalog. apparently its 110 lbs. It was optional for some of the bench mounted sharpeners.
I also posted the in the "general" section but did not get any responses, so trying it here as well...
I got a nice Reed 204R vise the other day.
Not planning to restore it since it is in good shape and I like the patina.
I took it apart, cleaned it and regreased and oiled it.
When I tried to install it on my bench, I realized that the base and the vise are not aligned.
I.e. if I align the mounting holes of the swivel base so they are the same distance from the front edge of the bench, the vise itself is not 90 degrees relative to this edge once I tighten it with the swivel base handle.
Since the design does not allow any adjustment with the serrated locking plate pulling everything into place, I would have to install the swivel base on an angle to make up for the offset.
Given how well designed Reed vises are, I would be really surprised if they had not taken that into account.
I don't think there is any room for error in assembling base and vise unless I am missing something?
Here's a picture that shows what I am talking about:
The vise is absolutely perpendicular to the edge of the WB but the mounting holes are off by a few degrees.
Take a careful look at the mounting ears on the base. Have one or more been broken off and brazed back on? They do not look positioned properly relative to each other.
Does the vise have its center bolt (the bolt coming up from the bottom of the swivel base that screws into the main body of the vise)? That bolt centers the vise on the swivel base, among other things. Practically, if it doesn't bump your OCD, it should be just as strong being slightly off center.![]()
I can only think of one way to assemble that vise. Once the center swivel bolt is in it is aligned so you just swivel it around and line it up on your bench top. How can that go wrong?
Is it the angle of your photo shot or lens distortion of some kind?
Yes, it is very hard to hold my iPhone straight above without getting some kind of distortion.
As far as I can tell, there is really nothing wrong with base, no repair, holes are symmetrical and bolt is centered.
Ok GJ vise guys I asked this in the vise info room but got nothing, I bought littletown vise # 112 had like 20 coats of paint so I didn't notice the slide is bent, so when it's closed 1 side is open, how should I try and straighten it, should I heat it first and whack it or just whack it. Trying not to snap slide off of course, thank you for any advice.
its made that way so the vertical plane of the fixed jaw can slightly extend beyond the bench your mounting it to.
Not the issue, maybe this picture helps:
Both ears for the bolts are flush with the workbench edge (take my word for it) but the jaws are not parallel to it.
I.e. the swivel base does not allow to lock the vise itself in a straight way. It is off by a few degrees.
And again, anything else that seems weird in the picture is just due to the angle it was taken.
Base is straight, swivel bolt is in the center, mounting holes are correct in relation to each other.
I think it’s simply that Reed did not ensure that the serrated locking mechanism in the swivel base allows for a straight position.
Have you looked at the toothed part inside that engages the base? Is it factory or did someone cobble it up? Is it less one tooth one way or the other?
For what is worth I have a couple of Reeds that are similar to yours.
It drives me nuts that Reed did not index the swivel lock cogs with the jaw line and feet.
Royce
maybe i just got proof that reed was one of the first us companies to outsource manufacturing to china in 1943 [emoji38]
I think you *may* have proof that wartime production was all about demand/speed/raw material utilization and the quality control that monitored *aesthetics* was disbanded to concentrate on function and production.
I’d be curious to compare prewar examples
I think that answers it.
Disappointing actually, glad I only paid 60 bucks for it
Thanks all for your input!
Well, whatever it is, this one has to go...
I guess I am just going to stick with more Wiltons moving forward...
