I'm a generator idiot...
dcg9381
Austin, TX
I've made two big mistakes with generators, so I thought I'd share.
We had an on-the-road failure of a generac that was in an RV and ended up buying a Briggs and Straton 5000 / 5500 watt unit while on a road trip. My mistake was that the 240V outlet in this generator had a 17A breaker on the 240 side. So it would only do 120V @ 20A or 240v @ 17A - really, only enough to barely power a single AC unit - and nothing else. It would frequently trip the breaker on the road and didn't begin to replace the on-board generator (5000 watts) that had malfunctioned, but would fire 2 AC units.
I eventually got wiser about 120V power - and bought a Champion 4000/4500, which didn't have 240V, but did have a 120V @ 30A connector - and it was great for the RV. Not quite as loud as the 5000/5500 - but this was my "go-to" for years with the RV and cheap at about $300.
After a carb rebuild (even with non-ethanol fuel, 100LL fuel) - I decided to switch to a dual-fuel champion. And I wanted 240V - for a welding rig that is semi-portable.
So I bought 2 of these:
https://www.championpowerequipment.com/product/100574-4000-watt-dual-fuel-open-frame-inverter/
They worked great on propane (never have filled the gas tank). They have the 30A RV connection that I'm after.. And they can "throttle down" at low load...
So I "sync'd" these today - added the kit to do that. Plugged in welder. Nothing.. .Then I notice "not for 240V use". Ugh!
Basically these are 120V only - and operate in-sync only, so no 240V. They can put down 50A, which is great for RVs (with multiple ACs) - but a total fail at firing a welder...
YMMV.
lis2323
Thanks for the info. But I would say you are no longer a “generator idiot!”
I, on the other hand am considered a “general idiot”.
egdede
I thought RV's had Onan generators. I don't know if saying that makes me an generator idiot or not.
D
dcg9381
Austin, TX
They are probably the biggest manufacturer of RV generators, yes. The RV I had, when it got really hot out (think 100+) - uninsulated fuel lines would vaporize fuel and the RV would shut down after about 15 minutes of run time on the highway.. It took me a while to sort that out, but when you're on family vacation and in a 38' RV, it's 100 degrees, and the house ACs won't run - it's a big problem.
Onans are also expensive. So if we're camped out off grid and I'm going to run a generator for days, I tend to switch to a portable genset to keep hours (and maintenance) off the Onan...
wrenchguy
NW Indiana
I'm a general/genny idiot too.
I fired a lincoln 400amp motor driven welder with this genny awhile back. The genny thought a gnat had tapped on. This time all went well.
Video,
Kielpo
As long as you aren't an idiot generator, we have too many of those these days.
StormcrowAz
Phoenix, AZ
You learned and nobody got hurt except your wallet.
We all pay for experience, in one way or another...
A decent genny that can adequately run my MM211 is on the long list. Would be nice for everything away from the shop. I've got a pretty old champion that bogs down on anything more then 16ga sheet. Has got me by so far, but would be nice to have something with a bit more juice.
D
dcg9381
Austin, TX
I don't need any welder on the road, but have a front "hitch mount" rig for my UTV... Need to weld a gate, or something around the yard, that's what I use it for...
