sberry
Living proof you can gob on as much as you want.
The zinc set screw connectors are ugly. I don't mind the steel ones.
Steel needs bushings, unless you get the plastic throated ones.
No requirement for that unless it's in the job specs.
Why is a steel connector more likely to skin a wire than zinc?
Its sharper... like the rigid.
Yeah I'm real confused here. The setscrew is on the outside of the conduit and the end to end connectors I use are pinched in the middle a bit to give the conduit a place to 'seat' which should protect the wire from any conduit edges.
On top of that, I deburr and give all of my conduit a bit of a chamfer on the inner edge using either a chamfer tool or a step drill after cutting it to length. I also run a finger around the full circumference to make sure there's no sharp edges left.
Sent from my Pixel 3 XL using Tapatalk
